Results 1 to 2 of 2
12-20-2004, 09:23 AM #1
200hp black max ´90 good engine need rebuild
i can buy a mercury black max 200hp build 1990
but one piston is ****t up
maby to hot or so
have this motor steel sleevs or chome
and is this a 2.4 or a 2.5 carb.
and is this a good engine
and how havy is this engine
all info is welkom
thnx
Marco from holland
12-20-2004, 09:51 AM #2
1990 V-6 Merc
1990 was the first year the 2.5's began to show up and the first were 14 petal reed models with bottom guide rods and pistons. There were also some 2.4's built that same year. The 2.4's were chrome bores and the 2.5's were steel. The 2.5 was way better than the 2.4 . Both weighed in at around 400 lbs. I suggest you get the serial # from the round disc located on the top of the block and have a dealer run it to be sure what you have. Otherwise you need a very experienced person to look for the differences.
Eagle One
