Results 1 to 6 of 6
Thread: Tachometer
12-08-2004, 03:36 AM #1Member
- Sep 2004
- lake texoma
- 98
Tachometer
Have a 1994 merc 225 carb motor-Does anyone know what I should be taching [high end]run 5500 rpm's with a 5 blade high five prop, should there be more than that?
Thanks
mikeGlastron Carlson cvx-20s--merc 225
Sea Doo speedster Twin engine
12-08-2004, 11:34 AM #2Member
- Mar 2002
- Key Largo,FL
- 69
5500rpm is fine for a stock motor. If you want more speed try a 3 blade prop, if you dont want to go to a 3blade try a trophy (4blade)
That high 5 is good for a hole shot, but after that it's slowing you down.
12-08-2004, 11:40 AM #3Member
- Sep 2004
- lake texoma
- 98
thanks for reply
I had been told that before about the five blade--it seems that the speed is not there [about 60] thanks alot for reply--I guess I will keep five blade for skiing, tubing etc......
12-08-2004, 12:03 PM #4Member
- Mar 2002
- Key Largo,FL
- 69
the five blade would be great for tubing etc. Have fun!!
12-08-2004, 12:28 PM #5
I get 7500 with my Merc High Five when I run it out.
I have a lot of gearcase in the water and am not surfacing it.
I used a three blade once and lost a bunch out of the hole and gained only 6 mph on top.
Each setup is different, got to try it out and see.mendo
MAD SCIENTIST
12-08-2004, 12:39 PM #6Member
- Sep 2004
- lake texoma
- 98
PROP
Hey Mendo
I really feel that I should be running in the mid 70's and am nowhere near it-- my lower unit is a little lower than it should be and I do not have a jackplate--my speedo could be off -next time I will gps it-- its kinda hard to believe that I can get 15 mph more out of it by propping and maybe a jackplate, but do not know--I have 2 other props I guess I will try assuming 5500 rpm is all I should be taching with stock motor--thanks for your input , anything helps
MikeGlastron Carlson cvx-20s--merc 225
