Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
    Nov 2003
    South Louisiana
    How to check timing on each individual cylinder
    Do i need some sort of degree wheel? How exactly is it done?
    Dave.
    Lake Racer
    Leesburg, Florida 34788
    dail indicator
    You can check each cylinder with a dail indicator.
    Do it just like your timming number one but do it six times.
    Just index each cylinder with the idicator counter clockwise .150 from tdc (the factory Hi-Po setting). You can put six marks on the flywheel and check each cylinder instead of just cylinder number one.
    Phone:352-267-7350 or text..
    Email:Winningeverytime@gmail.com
    Jul 2002
    Lafitte, La
    dave to be honest you can get a white out pencil and just put a timing mark on the flywheel using a screw driver in the cyl, it won't have to be precise, it will either by way off or very close. if your using it for troubleshooting. i the number of the cyl for the reference #.
    Craig Creppel
    DR-20 TRIAD
    ALLISON XB 2002
    Nov 2003
    South Louisiana
    got ya
    Thanks Phil and Craig. I figured it had to be fairly simple to check.
    Dave.
    Lake Racer
    Jul 2002
    Lafitte, La
    david sorry about all the humbug i wrote, kinda did it fast. what i meant is if you are using each cyl to troubleshoot eletrical problem, the timing is going to be close to your mark, dead on, or not in the pic, or reading another cyl. that's why i use the cyl # for the timing mark on flywheel, and not just a mark. also if you do get a dial indicator i normally mark the 25* mark using the cyl # and a different color marker. usually white= tdc and red=25*
    i went back and read my post it looks like i was smoking crack!
    Craig Creppel
    DR-20 TRIAD
    ALLISON XB 2002
    Nov 2003
    South Louisiana
    Thats ok
    I got the basic idea. Just going over & checking out everything on my motor before i put a little wheel on it and turn it up. Dave.
    Lake Racer
    Timing X 6
    Incert a JSRE dial indicater ( hint hint , lol.... ) in each plug hole and turn the flywheel clockwise until "O" ( TDC ) is established then turn the the flywheel back counter clockwise .150" , stop and mark flywheel . this establishes 25 degrees ( .170" = 27 degress and so on ) do this same procedure on all six holes and you should have 12 marks ( 6 TDC and 6 25 degrees to correspond with each plugs timing ) The dial indicator is the ONLY way to do the job you are attempting in an accurate manner.....
    Good luck,
    Jay @ JSRE
    Nov 2003
    South Louisiana
    Jay
    How much for the dial indicator?
    Lake Racer
    JSRE dial indicator
    David ,
    $40.00 + freight complete with easy to use instructions
    Jay @ JSRE
    NE Louisiana
    I use a piston stop. It will do almost the same thing as a dial indicator as far as finding TDC, but a lot cheaper.
    I count my teeth on the flywheel, compare to 360* to figure the tooth to degree ratio. From there it's down hill.
    Chillicothe , Ohio
    Actually a piston stop is the only true accurate way to establish TDC . With a dial indicator TDC can vary slightly because of rod dwell. Is a small detail , but when you wanna get picky its the cool deal. TB
  12. #12
    You don't need to know where TDC is. It's not used for anything. The dial indicator will measure accurately where .150 before is, or any other measurement. It can be marked on the flywheel for all six. What else do you need to know (for a merc)?
    Jim
  13. #13
    Chillicothe , Ohio
    You don't need know where TDC is , its not used for anything Yes the indicator will accurately measure the .150" or whatever you want , but how do you determine a starting point next time you have your indicator in , roll to what you think is TDC and watch how much you can rock the flywheel back and forth with no indicator movement , its rod dwell , yes i know im being picky but the racing i've been involved in didn't allow imperfections.
    TB
  14. #14
    Rod dwell is only important if you are trying to measure TDC, thats the whole point. It's easy to zero the indicator even if there is dwell. If you want to measure something else measure it from the .150 point. its accurate. It's a lot more accurate that counting teeth.
    It does not make sense to measure the timing from the TDC point when it is more difficult to determine. TDC can be accurately measured with a dial indicator, it's just not necessary.
    Jim
  15. #15
    Chillicothe , Ohio
    Im sorry im failing to understand what you are saying " probaly my ignorance". I know the answer , but the .150" timing is .150" from what . Everything is measured from TDC and if there is a couple degrees variation is that ok for a race engine , not for me. Sorry for the confusion . TB
