Results 1 to 7 of 7
    Sep 2004
    cold old uk
    merc250xs V 2.5xs
    so which is best,look at the weight differnce between 2.5 block and the 3.0 block any one got any opinions on these re power and speed and fuel economy, thinking of fitting a pair, now not sure which is best,re power to weight ratio?
    Lannon WI
    A heavy rig will like the 3.0 torque better.
    If its lighter the 2.5 is your choice.
    What your intended use and what type of hull?
    2006 Action Marine Comp
    1980 Ventrua 2
    Istanbul
    As far as I've been told both are great engines, so you won't be disappointed in either way.
    I also read here that the 250XS gave 269hp in dyno-tests (i couldn't remember who wrote it), but 2.5XS revs higher.
    Like Laker said, it's up to your application and needs of your hull...
    ~Outboard Maniac~
    Sep 2004
    Long Beach, N.Y.
    both great engines for what there purpose is, like laker said the 2.5xs is meant for a lighter hull.
    Sep 2004
    cold old uk
    250 xs v 2.5 xs
    i would be putting them on a 28 foot kevlar mono hull , which has been built as light weight,its a big old boat though and requires the extra long shaft, what is the fuel compparison like ?
    Fremont, WI
    if you need an XL, then the choice is easy, the 250XS is the only one availble in an XL
    I would say that the 250XS is the better motor for your rig anyway
    Sep 2004
    cold old uk
    cheers
    thanks jimmy ,the reports look good on them the 250 xs that is ,had a go on one the other day , really quiet, but the merc spec shows them as real heavy weight .
