View Poll Results: Is your motor stock or modified
Voters
128. You may not vote on this poll
  • stock
    44 34.38%
  • modified
    84 65.63%
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 75
    Aug 2002
    Lake Hopatcong new jersey
    Question Your motor stock or modified?????
    Is your motor stock or is it modified if so what have you done to it, and do you do your own work?
    My motor is slightly modified bored 10 over with the heads cut and boysen reeds, with relieved exhaust.
    Fort Lupton,CO
    Slighty moded. No can, relieved exh(talon 2.5 mod). Mild port work. Mod vp carbs.
    Guy that built it said when I asked him how hard to turn it, 7500 rpm if you want 2 seasons or keep it under 7k and it will live a long time. So under 7k it is.
    Fellow G-Man,
    Sunshine Syndicate, Mid West Chapter
    1975, 16' Checkmate Tri-mate 2.4 200+
    Currently undergoing overhaul.
    260 with:
    SVS
    Seebold flywheel
    Jim
    Jul 2001
    Springfield, MO
    Didn't do any of these mods myself, but this is what the previous owner said was done .....
    89' 200GT 3-Liter Looper
    cut heads (140psi)
    Wiesco forged pistons
    Boysen reeds
    Relieved Exhaust
    Carbs re-jetted
    Not sure if it's making much more power than stock, but it's at least enough to push my Vegas to 80mph
    Ian
    ...boatless for now.
    The Helmut-S&F machine:
    Sportmaster lower unit(2 - not modified) 1.75:1, 1.87:1 ratios, 14.5 x 32P Mercury Lab Cleaver.
    1998 STV Euroski, standard weight, "ski" bottom, full interior (stereo, amps, and all!)
    1996 2.5 260 EFI Offshore, 300-spec cylinder porting and ported exhaust, 175 lbs. compression, JSRE dry-stacked drag exhaust, JSRE lightened and balanced rods and wrist pins, Marles US1 lightened, balanced, and pinned Mercury high-performance pistons, Brucato SVS, Brucato PCU with extension harness and Steamwheel, Geforce lightened flywheel.
    Oh, and more on the way
    Jun 2004
    Plymouth/Saginaw, Michigan
    If You Count
    relieved exaust as modified then I'm in! !977 Mercury 1500
    Jul 2004
    St.Pete, FL
    2.5 LOTS OF GOOD STUFF....
    But I dont know what is done... I would have to ask Talon2.5
    He Built it...lol
    But I turn 6800-7200 approx. 95mph 18 Talon
    But Officer There is NO-WAKE over 100mph............
    21 Hydraskiff
    Beautiful Lutz Florida
    "Stock"97' Merc.300 Drag.There is NOTHING!!!stock about this motor--even if that is the way Mercury built it! Mike T.
    Jul 2002
    Missouri
    can you say fuel injected 3 cyl omc? with expansion chamber! msd! 2- lb flywheel! custom head! ported out the wazoo!and bores like coffee cans! ON A JON BOAT!!haha
    nitrous/fuel expert
    RIP-MY FRIEND WAYNE T
    YOU WILL B MISSED
  10. Likes JrCRXHF liked this post
  11. #10
    Dec 2003
    Meadow Vista, CA
    1750-upgraded charging system, exhaust relief, solid mounts. (The family workhorse, super reliable ski/tow machine)
    2.4-cut heads, lightweight cowl, exhaust relief, one-piece adaptor, solid mounts, cooling mods.
    2.4-2.5 pistons, exhaust chest work, port work, still in assembly.
    40hp OMC-cooling modified, (works great now on the pontoon!!)
    mendo
    MAD SCIENTIST
  12. #11
    Mar 2002
    Skow-vegas,Maine
    2.4 chrome bore fishin mota, daul stage reedz , tuned reed blocks , no can , opened mid , porte matched tuner thru the plate , drystacked , jetted , 30cc heads , 150 comp. , lightened flywheel , light weight cowl , sporty lower w/ 1.87:1 , and velocity stacks with a 1"spacer
    OneBigAssMistakeAmerica
    "No good deed goes unpunished"
    81 Sanger Alleycat
    1984 21' Carrazza w/mariner magnum 2.5 200 EFI
    www.rinaldi-engines.com
  13. #12
    Maurepas, Louisiana
    re:modded motors
    Steel sleeved pro max block, stuffed full of JSRE, Marles,Brucato'goodies......currently running the 40a system, but with a purdy JSRE lightweight flywheel setting on the bench waiting for the 16amp reg and rectifier soon....
    Russ Benton
    Allison XB-2003 w/JSRE Pro Max
    Allison XR-2001 w/260 +
  14. #13
    Aug 2004
    Lake Wissota, Wi.
    Stock, cept
    Boysens, nose cone, opened exhaust.
    335lb. Vector, 750lb. Ventura II
    Hydrostream Addict Hot Evinrude 200 crossflow
  15. #14
    WASHINGTON N.C.. I TOO HAVE A BOATING PROBLEM
    This one's stock, (except hogged exhaust chest, no can, relieved exhaust), and it only turns 6500, but like 175checkmate said about it lasting longer..........235 hours this season, and "its still alive"
    The motors that I port and run tight heads, (150-160 psi) only seem to last 150 hours or so, at 6800 to 7400 RPM
    Sure I miss that extra 10 MPH, but now adays, I am happy running 55 or 60 MPH on the pad............until something tries to pass me.
    JOHN MASON
    '83/VECTOR/MERC 200-- SOLD
    '98 Quartershot T-3/ MERC 200
    "If your not living on the edge, your taking up to much space"
  16. #15
    Aug 2003
    Sweetwater, New Jersey
    300X-STOCK
    With all the problems, I have had with this engine. I don't really want to think about problems if I modified it. Chuck.
    CHUCK & TRACY FREELAND
    1990 25 Talon with twin Merc. 300XS's
    1983 Mako 21 with Merc. 225.
    www.Fullthrottlepowerboats.com
    NEVER FORGET 9/11
    Give a man a fish, and he eats for a day. Give a man a welfare check, a free cellphone, food stamps, section 8 housing, a six-pack of beer and he'll vote for a Democrat the rest of his life.
  17. Likes bbezok liked this post
