Results 1 to 5 of 5
Thread: No start 1991 2.4 bridgeport
09-13-2004, 08:32 PM #1
I have a 91 pro comp 2.4 efi. I went out to my hangout yesterday and when I pulled up to he beach it started intermittantly dropping a cylinder just at idle. When I went to leave, it wouldn't start. I got it home and checked it out. It has spark but no injector pulse. Think the ananlog box went bad??? I don't know where to look for diag procedures. I'm a automotive drivability tech but I need a flow chart with some kind of specs. Thanks, if you can help.
09-14-2004, 11:07 AM #2
The injectors all have a common power wire red/yellow stripe, check that you have power on this wire.It goes to the hot side of the solenoid to the ecu and each injector.Dave
09-28-2004, 02:59 PM #3
Found it!!! Stator.
The low speed red and blue wires are open that go to the outer switchbox which also triggers the injectors.
09-28-2004, 03:01 PM #4
Stator fo sale????
Anyone have a 398-5454-a35 stator for sale??
09-28-2004, 07:34 PM #5
stator
hi there, not to diss on merc, i have had good luck with rapair electronics on my skater w/2.4 efi's, their stators are open wound so they stay cooler during operation, find a local dealer or drop me a line.
