Results 1 to 11 of 11
Thread: 280 rev limiter
08-29-2004, 01:39 PM #15000 RPM
- Aug 2003
- congers n.y.
- 101
280 rev limiter
recently purchased a 280, & was wondering what the limits are as far as how high you can spin the motor with that charging system & if rapair or someone else can up the rpms on the 8200 box, im aware I could go to the old style electronics but was just wondering how far you can go with the new charging system.
Fast Phil
08-29-2004, 03:06 PM #2
rev limit
For the consumer 280 - 7700 rpm.
For the Offshore Race - 8250 rpm.
Rapair has a few tricks to get more rpm from the stock electronics - 8700 rpm is fairly consistent, with a few turning as much as 9200 rpm.
I hope this helps,Disclaimer: Everything I post is just my .02, and should be take only as opinion. These opinions tend to be notoriously WRONG, and any that are correct, can only be attributed to my being dropped on my head as a small child - repeatedly.
08-29-2004, 03:17 PM #35000 RPM
- Aug 2003
- congers n.y.
- 101
280 rev limit
Thanks wayne I guess ill get in touch with rapair & have them turn it up 9000 would be nice can the alternator & crank withstand those revs, meaning the added load to the upper crank to drive the alternator; I was advised to go to a lightwt. flywheel when around 9000,& also some warning about damaging the fields,etc. in the alternator with high revs are a issue
Fast Phil
08-29-2004, 03:33 PM #4
Phil,
I have not heard about any alternator failures as of yet. But sustained use at 9000 rpm might be an issue eventually if the internal voltage regulator should fail. I have Drag electronics on the 280 on my STV River Rocket, and I am happy so far as a lake use boat - no racing.
08-29-2004, 04:09 PM #55000 RPM
- Aug 2003
- congers n.y.
- 101
280 rev limits
thats pretty much what ive heard I have a 87 lowdeck stv i purchased from diamond marine when they were in long island ,I guess i should see if i can spin my 32 cleaver high enough with the stock 280 to see if rpms are even a issue but sooner or later, with some power upgrades,i might have to deal with the higher rpms & I liked the idea of keeping the charging system,I also have a 30 lighting et which probably will spin up about 600 or so more than the 32 any idea how the stock 280 will run on my setup with these props, what kind of numbers are you turning
Fast Phil
08-29-2004, 05:17 PM #6
I can turn a Merc lab 32 cleaver 7500 on my 98 Euro, so you should be able to do better.
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
08-29-2004, 05:53 PM #75000 RPM
- Aug 2003
- congers n.y.
- 101
280 rev limit
thats a nice looking rig you got I was running a modified 2.4 W/ 165 comp on mine & was able to spin the 32 to 7600 with every thing just right was hoping the stock 280 would do the same or better
Fast Phil
08-29-2004, 06:11 PM #8
Our 280 has had the limiter removed by Rapair and as Wayne stated earlier, it will rev between 8700 and 9200 quite easily. The only problem is that the ignition will break up on occasion around 8500 and then run normal. Sure can mess up a good run when racing your buddies. It will spin a 28 ET up to 8900 fairly consistently. Never tried anything bigger.
08-29-2004, 06:20 PM #9
What's the alternative ????
1. 260 Electronics
2. Rapair modified box
3. Brucato PCU
Just depends on what your looking forEldest Moron Brother
SOLD 95 Euroski
99 2.5 280+
Delta w/ 75 Stinger 55+
RIP RPM Racing
08-29-2004, 06:22 PM #105000 RPM
- Aug 2003
- congers n.y.
- 101
280 rev limit
is that a stock 280 & whats it on any idea what astock 280 with a 32 lab on a 87 stv might do
Fast Phil
08-29-2004, 06:32 PM #11
Depending on conditions, set up and the driver, you just might ping that rev limiter
I have w/ offshore boxEldest Moron Brother
SOLD 95 Euroski
99 2.5 280+
RIP RPM Racing
