Results 16 to 30 of 43
07-12-2004, 09:11 PM #16Junior Member
- Apr 2004
- cali
- 20
is nikasil and chrome the same thing?
chrome is that shiney stuff on your car!.
nicasil is dat stuff in da hole in da sillynders of da moter on da botes
NiCom®- Nickel Silicon Carbide Composite
NiCom® plated cylinder bores on high performance marine engines
As an alternative to hard chrome plating, U.S. Chrome now offers a Nickel Silicon Carbide composite coating. NiCom® is an electroplated nickel matrix with hard particles, of SiC, uniformly dispersed throughout the coating. NiCom® has a plated hardness between 550 and 650 HV100; however the particles are much harder (SiC: 2400 HVN) which give this coating excellent sliding wear resistance. The mating surface "rides" on the surface of the hard particles, not on the nickel matrix, which is the principle behind NiCom®'s excellent sliding wear characteristics.
NiCom® can be applied in a range of thicknesses from 0.0005" to 0.030" on a wide variety of materials. NiCom® is functional as plated in thin deposits, but can be machined or honed in heavier deposits.Last edited by hugh j.; 07-12-2004 at 09:15 PM.
01-14-2016, 06:34 PM #17The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
01-14-2016, 07:12 PM #18
07-31-2016, 10:08 AM #19
I just found this thread in a search. Very interesting read from some knowlegable people. I am older than most here and started racing outboards in 1978 and when you race you must know your equipment and how to work on it. My experiance with 2.4 chrome Mercs tell me that although Nicom/Nikasil is harder and more durable chrome motors last way longer. I suppose this would be more of a ring issue than cylinder plating matieral so i have a question. In a lake boat situation that see`s lot`s of cruise time even with 260`s or 280`s why not use some other type ring instead of the gold coated one`s from Mercury?
DB
07-31-2016, 12:58 PM #20
have been using moly rings they are friendlier
on bores and are broken in as soon as you start the motor no need to pussy foot around .
07-31-2016, 08:42 PM #21
Good to know. Where do you get molly rings for a 2.5? How about Pro-Marine?
07-31-2016, 09:56 PM #225000 RPM
- Aug 2008
- Stoneville NC
- 677
Ductile iron sleeves are fine for a fishing motor.. I even turn my 245 which was a 260 before I went to carbs now turning 7500 rpms on iron sleeves and top pinned pistons..
20ft Gambler with Merc 260
Too many projects to liist..
07-31-2016, 10:03 PM #23
07-31-2016, 10:05 PM #24
08-01-2016, 06:13 AM #25
I`ve done that twice with great results and a bud is doing it right now. I did it for nitrous.
DB
08-01-2016, 08:23 AM #26
08-01-2016, 09:16 AM #27Markus' Performance Boating Links:
08-01-2016, 10:10 AM #28
funny,I didn't realize this post started in 04, amazing how long we have all been on here. honestly I have heard sleeves being refered to as steel and cast iron for along time and was not sure myself until i did some reading on it. When you bore one you know right away its not really steel it cuts out in tiny chips not like ribbons from steel or aluminum.Dave
08-01-2016, 07:30 PM #295000 RPM
- Aug 2008
- Stoneville NC
- 677
James Perry can make sleeves and does a fantastic job if you can get him to do them for you. Any port timing you want. CNC Mill set up.. Also oversized to fit your hole..
08-15-2016, 09:22 AM #305000 RPM
- Nov 2002
- Lake Lanier - Atlanta, GA
- 149
Starting on page 2 of the first linked document below, you can read information about Mercury Marine's research with Mercosil aluminum block & bore and their production:
http://www.ncccoat.com/PDF/MercuryNC...icalpapers.pdf
Here is another great article. http://www.sunnen.com/NewsDetails.aspx?NewsID=11
Another great article... Especially good near the end! http://www.mmsonline.com/articles/ne...cylinder-bores
