Results 1 to 9 of 9
Thread: 1979 hydrostream viking setback
06-28-2004, 07:13 PM #1Junior Member
- Jun 2004
- louisiana
- 13
I am currently setting up a 18 foot viking. need help to figure proper jackplate setback. any help would be appreciated. my engine will be a 2.4 merc 200, thanks.
06-28-2004, 07:17 PM #25000 RPM
- Jun 2004
- Pefferlaw Ontario Canada
- 172
Im running just the jackplate, i think it gives about 5inch, seems to work fine for me. same hull and motor as you.
Aquarius Aqua-Cat, 50hp tldi Tohatsu
Aquarius Mini-Cat 25hp Tohatsu
Todd Billinger
06-28-2004, 08:02 PM #3Junior Member
- Jun 2004
- louisiana
- 13
viking setback
thanks binger. i will try the 5 inch for sure. appreciare the info. how fast are you running with that combo? what size,type prop?
06-28-2004, 08:09 PM #4
Set back...
86 V-King YT.
I'm running 8" setback with a 175 Merc and it just went 80 mph this weekend with a new prop.
Nose cone is even with the pad.
Good luck.
Mac.
06-29-2004, 12:56 PM #57000 RPM
- Canada
- 2,428
- 35
Need more info ........
Here is what you need to tell me ...... What hull ( VEE or YT tunnel ) , where is the fuel tank , what is your use for the boat going to be ( speed or all around use ) , your weight , do you carry passengers alot .
These are all factors in setting up a boat to run its best.
Will be glad to help ..
Jeff
06-29-2004, 04:51 PM #6Junior Member
- Jun 2004
- louisiana
- 13
more info
jeff, the hull is a v,into about a 14 inch pad all the way to the transom. tank is in the back. my weight is 320. not intending to be all out racing, but a good hole shot. isometimes race a few friends but i always get my ass kicked.(had a bass rig before) then i bought this hydrostream and i am setting it all up for mostly cruising, but want to be able to finally kick a little ass myself. it is coming along good so far, just want to get setup as close as possible. thanks
06-29-2004, 05:02 PM #77000 RPM
- Canada
- 2,428
- 35
OK
Well that being noted you would probably want to be in the 6-7" range. If you are setting it up for mostly cruzzinn with a bit of top end in mind. You being 320 + the addition of a passenger ........ 7" is probably right-on. Your gearcase should have a CLE or a nose cone of some sort on it to really get it up there and keep good water pressure. Remember to rigg or have some one rigg it with all/most of your equipment ( trim pumps , jack pump if required , batterie , fuel pump ... etc etc ) on the port side to add in counteracting your weight.
Time spent doing it right now will only give you more time on the water. Steering , rigging , jackplate height ...... etc ....... etc !!
Jeff
PS .. feel free to ask !!!
06-29-2004, 09:16 PM #8Junior Member
- Jun 2004
- louisiana
- 13
viking setback
thanks for the info,jeff. i will try that combo and then post results when done. thanks again.
06-29-2004, 11:00 PM #9
Around here,
most of the V-king's use a jackplate with 4-6 inches setback, and a good starting point is to level the propshaft with the drainplug. which also means you need to make sure you have low water pickups. With a good 2.4 on a v-king you should be able to see 80's conservatively if set up right. ~GB
Just remember! Its always easier to beg for forgiveness than ask for permission!
