Results 1 to 6 of 6
    Jun 2002
    Washington
    Looking for HST info
    Does anybody know if the original HST's (Pipcorn's Hydrostream's) had a slight hook incorporated in the pad? I have looked at 2 hulls, both 1990's, and they appear to have about a 1/8" hook starting about 12" - 16" from the back edge of the pad. It looks to be only on the very bottom surface and not the 2 smaller surfaces on either side of the pad.
    If this was intentional, has anybody removed it in an attempt to help with bow lift? Would it become a little too flighty at the upper end?
    Thanks, in advance, for any info, Mike
    Aug 2002
    Winnipeg, Canada
    I'll let you know. I'm having Randy Pierson (GPI) look at mine when we go down there in a couple of weeks.
    I'm thinking that the hook could be the case for some.
    May 2002
    Debary, Florida
    Mine has no hook, if it did it was removed before I got it. When I blueprinted the bottom it was already pretty straight, just rippled gel coat
    Wile E. Coyote: (acceleratus vulgaris)
    Its amazing how heavy a GPS can be.....
    Mines straight as an arrow
    yep.
    No hook in mine either....
    Straight and flat all the way. Mine has also been blueprinted though. I don't think Howard intended any hook in them. I would take it out if I were you.
    Balzy, Head Amigo
    Leakdown Testers / Balz to the Wall Racing Website Here:
    BALZ TO THE WALL RACING
    Jun 2002
    Washington
    That is what I thought. I was getting ready to remove it and then got to thinking about it and I just wanted to make sure it wasn't put there on purpose to fix a handling problem. Kind of interesting how 2 boats are identical though.
    It will be very easy to remove.
    Thanks, Mike
