Results 1 to 4 of 4
    Mar 2004
    WISCONSIN
    Need Help W/a Merc Part
    I HAVE TWIN 1994 MERC 2.5 EFI'S AND ON MY LEFT MOTOR THE PLATE THAT HOLDS THE SHIFT AND THROTTLE CABELS DOWN(AT THE FRONT OF THE MOTOR) IS BROKEN.I HAVE TRIED FOUR DIFFERENT MERC DEALERS AND NO ONE HAS A LISTING FOR THIS PART.I REMOVED IT AND THE ONLY PART NUMBER WAS ON AN ALUMINUM LINK IN BETWEEN THE UPPER AND LOWER PLASTIC PARTS.WE ORDERED IT AND GOT JUST THAT LINK.WHAT I NEED NEED IS THE UPPER PLASTIC PLATE.I HAVE SINCE RE-INSTALLED IT AND ZIP STRIPPED THE CABLES DOWN.THIS WILL WORK BUT DOES NOT LOOK PROFESSIONAL.CAN ANY ONE HELP OR DO I NEED TO POST A PICTURE?
    Hi,
    Is letter "D" what you're looking for?
    Mar 2004
    WISCONSIN
    GREG,THANKS FOR THE QUICK REPLY.WHAT HAPPENED ON THE SITE.I COULDNT GET IN FOR A WHILE.THAT IS WHAT THE ONE LOOKS LIKE ON MY RIGHT MOTOR.THE ONE THAT IS BROKEN IS HORIZONTALLY MOUNTED.LATCHES AT THE BOTTOM AND THEN A PLATE GOES ACROSS THE CABLES AND FITS INTO AN OPENING AT THE OTHER SIDE.THE BOTTOM LATCH AND THE PLATE ARE PLASTIC AND THE LINK INBETWEEN IS ALUMINUM.THE LINK HAS A MERC PART NUMBER ON IT SO I BELIEVE IT IS NOT AFTERMARKET.
    Any Mercury Dealer should have no problem obtaining that part for you. Diamond Marine is an authorized Mercury dealer - give them a call, I'm sure they can assist you.
