Results 1 to 2 of 2
Thread: 2.4 Rebuild questions
05-10-2004, 08:35 AM #15000 RPM
- Kenosha County, WI
- 207
1. What do you use on the connecting rod bolts to hold them in? Loctite red, blue, or something else?
2. What tricks do you use to reassemble the connection rod, main, and piston bearings? Can you use a little assembly lube to hold them in place?
Thanks.1989 Ski Centurion Barefoot Warrior
1995 Hurricane Fundeck "S.S. Putz Putz"
05-10-2004, 08:54 AM #25000 RPM
- May 2003
- Hazel Green, ALABAMA
- 282
We've always used Red Loctite.....as far as the bearings, YES the assembly lube holds the rollers in place or Vaseline works just fine too.
