Results 1 to 3 of 3
Thread: Injector Flow Rate?
05-02-2004, 01:59 PM #15000 RPM
- Aug 2001
- Wausau Wis
- 133
Injector Flow Rate?
I sent my injectors out to Tony Brucato and had them cleaned. My Question is their a preferred flow rate for my cylinders. I have my flow chart and my injectors are all labeled so that I can now put different flowing injectors where ever I want. I was told that I should put a higher flowing injector in number 6 cyl, but for the rest it does not make much difference. Does no. 6 cyl run hotter ? Engine is a 2.4 BP Chrome Bore and 2 steel sleeves No 2 and no 6.
Thanks Paul
05-02-2004, 08:57 PM #2
Injectors
I would install the 2 highest flow injectors in the 2 steel sleeved cylinders, they are the hotter cylinders.
LeeLee Sanderson
05-02-2004, 09:01 PM #35000 RPM
- Aug 2001
- Wausau Wis
- 133
Thanks for the reply, I was kinda thinking the same thing but not too sure.
