Results 1 to 15 of 21
04-15-2004, 06:13 PM #1Junior Member
- Oct 2003
- Invercargill New Zealand
- 12
bullet 1750 standing up low speeds
Have a bullet 1750 with a merc 200 100 ltre ss tank transom mounted ,boat at low speed wants to stand up when taking off
had an issue last week when bilge not working ,teaching someone to ski with training bar &hull filled up with water real quick
need some advice on motor set up &what to do about a beter bilge pump
04-15-2004, 09:35 PM #2
What do you mean the boat wants to "stand up when taknig off at low speeds"? Do you mean it wants to come off of plane and the nose starts to rise? What speed does it do this at? Any more details would be great. As far as the bilge pump goes, it sounds like you just need to fix it
Ian
...boatless for now.
04-15-2004, 10:09 PM #3Junior Member
- Oct 2003
- 12
nose comes up when taking off
even when trimmed right in
would trim tabs help with this
getting bigger bilge that works
cheers
Keith
04-16-2004, 06:28 AM #4
How many people do you have on the boat? If you've got it loaded down with people, the nose is probably going to stand up pretty high until you plane off. Maybe try one of those hydrofoils that goes on the cavitation plate on the motor.
Ian
04-16-2004, 01:22 PM #56000 RPM
- Oct 2003
- Rome, NY
- 1,052
If I'm not mistaken, thats what happens when you accelerate in a boat, especially outboard from a standing start, especially a small boat with a big outboard on the back, bow rise happens, stick people as far forward as possible to try to remedy it.
04-16-2004, 01:45 PM #6
When Skiiing I put weight in the bow, cooler, extra gas, etc. also looking at your picture, how high is the ski pole? mine is just high enough to clear the motor. On one of my boats I put the battery in the front also to help get on plane quicker.
mendo
MAD SCIENTIST
04-16-2004, 01:49 PM #7
PLANEING
I had a Vector with a mod OMC V6 that went way high at the launch. I tried to pull a skiier [for the first time] from the removable ski pole that came mounted just behind the front seats. The nose was lifted straight up and the boat did a barrel roll, taking on a bunch of water. The ropes pull, pulled the bow staraight up and torque rolled it over. I ,then, had a custom bar built to fit into the splashwell and pull from a point right above the engine cowling, so I had no bow lift. I even pulled parasails with it afterwards. My GS has a built in pylon just behind the rear seats and it still lifts the bow more than I would like...
JR
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
04-16-2004, 07:41 PM #8Junior Member
- Oct 2003
- 12
thanks for the advice
was looking into puting "smart tabs"&a hydrofoil on cav plate on motor has anyone had experience with these??
boat does 72 mph(118kmh) on tke gps with a 28 4 blader
thought that the tabs might help with the chine walk that comes through at 60 +any ideas
would a jack plate be of heelp or not required onthis size hull approx 17.5 ft
04-17-2004, 01:48 AM #96000 RPM
- Oct 2003
- Rome, NY
- 1,052
A jackplate will help with the topspeed and also allow you to drop the motor down to get good bite for skiing. The chinewalking you are seeing is most likely the product of the motor being too low, raising the motor will help and the added setback of most jack plates will also help in balancing the hull at speed. Getting the motor higher will help, it appears the bullet has a very shallow hull. I am no expert... but you may be able to get transom wedges... to allow you to 'tuck in' the engine more for a flatter take off, any ideas from the experts???
04-19-2004, 06:35 AM #10
Jackplate
Unless you are running a 15inch mid section you will need a jack plate. I don't think i have seen any 1750's without them. I would expect one set up with a 200 to do a little better than 72MPh if set up is right.
The chine walk is a feature of bullets and you will just have to learn to drive through it athough good set up will help you handle this. Cabels on your wing steering should be as tight as possible without jamming the steering.
1850 bullet - 200 Yammy Vmax
04-19-2004, 07:10 PM #11Junior Member
- Oct 2003
- 12
thanks dave for the advice ,looking at putting bow tank in also
do you know where to source jackplates in NZ??
04-20-2004, 07:31 AM #12
I just made my own out of angle aluminum but you could try Fish City or Rollos Marine, both in Hamilton.
If you are thinking of putting a petrol tank in the bow , I wouldn't. You will upset the ballance of the boat if you remove the weight from the back. You could put a ballast tanks in the front. I run one whick holds about 30 Ltrs. I can pick up or dump water while running. This improves the rough water handling and helps hold the boat on plane at slow speeds for skiing.
04-20-2004, 08:35 AM #13Supporting Vendor
- Jul 2002
- Gallatin, TN
- 236
Foil
I have a short foil that will work for what you are doing.
04-20-2004, 03:28 PM #14Junior Member
- Oct 2003
- 12
hi dave can you post some pics of your jack plate
chhers
keith
04-20-2004, 03:31 PM #15Junior Member
- Oct 2003
- 12
hi redbullet do you have dimensions of plate
keef
