Results 1 to 7 of 7
Thread: Advice on replacement coils
03-29-2004, 04:18 PM #1
If going from stock pro max type coils on a fairly stock motor, basically stock limiter ,,,,and upgrading to a healthy JSRE motor with more ponies , anticapating much more rpm's,,,,what type coil setup would be perferable?
Thanks, RBRuss Benton
Allison XB-2003 w/JSRE Pro Max
Allison XR-2001 w/260 +
03-31-2004, 12:42 PM #2
No help ?
RB
Russ Benton
03-31-2004, 01:03 PM #3
Stock is all there is
I seriosly doubt the PM coils are any different than the HP coils...if you really want to do something different you could go MSD but that's an entirely new system.
David
03-31-2004, 06:19 PM #4
Coils
RB, my Promax came with blue coils. While I had the engine down for a rebuild, I pulled the coil covers and found all the magnets cracked. I ordered all new coils, the new ones are black. I called 3 Merc. Hi-po dealers and was told they are all the same. The new ones run just as good as the cracked ones. Maybe I didn't need to replace them?
03-31-2004, 06:20 PM #5
Thanks David
Doing some more research on em'.
Appreciate the reply.
RussRuss Benton
03-31-2004, 06:27 PM #6
Black ones here
Mine has the black coils I have seen on others. They seem to fire alright, maybe just replace the wires and call it good nough!
Thanks, RussRuss Benton
04-01-2004, 07:22 AM #7
Wires
Go to Magnecor's web page. Great prices...great wires, great noise supression. Have already made wires for outboards.
David
