Results 1 to 10 of 10
Thread: switching drums to rotors ?
03-28-2004, 05:50 PM #1
jerry wants to switch the old drum brakes on his trailer to the new rotor type setup , anyone done this ? whos got the best price on the stuff ??
dont ever use apple drywall company on long island , they suck !!!!!!
03-28-2004, 08:42 PM #2
No rot components:
I don't know how much it is, but this company builds an all aluminum and stainless trailer and the sell the individual components as well. Good luck, Jay. www.rollsaxle.com
03-28-2004, 09:11 PM #35000 RPM
- May 2003
- South Ga.
- 294
Disc Brakes
Try here: www.northerntool.com or here:http://shop.easternmarine.com/acb/sh...D=361&CATID=23
03-28-2004, 10:24 PM #4
It has been my experience you can buy anything for a trailer the cheapest from Elkhart Indiana. There are a ton of trailer places there.
04-06-2004, 06:15 PM #56000 RPM
- Oct 2002
- Dallas
- 1,520
Hmmm...
jerry got a brake problem.
jerry drum breaks are probably rusted and old.
jerry needs disc brakes.
If jerry got a big boat and trailer with lot of jerry crap so the whole things weighs more than 3,500 lbs then jerry should buy the best disc brakes on the market...jerry should get kodiak brakes.
Kodiak brakes have a vented rotor (unlike the cheap tie downs) and come in different sizes 10", 12" etc. I believe you can buy them directly from Kodiak or from a distributor near jerry's home toon town.
04-27-2004, 11:13 PM #65000 RPM
- Jun 2001
- Baton Rouge, La.
- 522
Tie Down Engineering
They make a complete kit. S/S rotors,aluminum calipers,S/S hardware. Make sure your coupler is compatibale with disc. Have installed both Tie Down and Kodiak. Tie Down wins.
Champion Trailers has a web site. They are outta Slidell,La. They sell Tie Down. I sell them for around 275.oo to do 2 wheels.Keep the Faith
Socially Disfuktional
06-02-2004, 04:30 PM #76000 RPM
- Florida
- 1,881
jerry
You will probably need to add a cut off switch/valve to the master cylinder to shut off the brake pressure in reverse. It is wired into the backup light circuit using a 5 wire instead of the 4 wire circuit. If you tow with another vehicle which does not have the 5 wire you will need a brake lock out to back up. Discs work just a well backwards as forwards so they need to be locked out when backing. It is sort of a pain.
Jim
06-02-2004, 05:01 PM #8
Jerry, try UFP they make a disc kit. I can get you a number when I'm back in the office tomorrow if you're interested. They're vented as well and standard equipment on Shoreland'r, Eagle and Prestige trailers. I've never had a problem with them.
Oh, and Jim is right about the brake cut out...you'll need one.'08 SRV
Yamaha 3.1 Phase III
06-02-2004, 08:29 PM #9
thanks , jerry got his stuff , hope to install this weekend . will post pics
06-29-2004, 07:07 PM #10
well a couple of weeks later and jerry is done . change the tounge to a 8 ft instead of 6 ft ran new lines for the new clean brake fluid ( old lines had water in them ) new l.e.d lights , new actuator made for disc brakes , new bunks and new carpet.....
