Results 1 to 10 of 10
03-24-2004, 02:24 AM #1Member
- Mar 2004
- near amsterdam (Huizen) Netherlands
- 43
a15 analog box turn clockwise or counter clockwise too turn richer
do i have to turn the potentio screw on the a 15 analog box clockwise or counterclockwise ??
03-24-2004, 07:26 PM #2
My notes say
Counter Clockwise is rich and 1/2 turn is 2 numbers. You may want to call Sean at Rapair to verify. I believe some of the early boxes could be either direction so its much better to have a tester. If you are not sure, try turning it 2 numbers and see if you can get it to 4 stroke. If not then go 4 numbers the opp way ( back to where you were plus 2 the opp way) and see if it will 4 stroke. You can determine which direction is correct for certain on your box in a pinch this way.
03-25-2004, 09:08 AM #3
Interesting
I was told that clockwise is richer on all analog ECUs. It seems to be the case on my A17 anyway.
Seems like Mercury has been doing all they can to confuse us.Markus' Performance Boating Links:
03-28-2004, 03:13 PM #4
The A15 is different. Counter clockwise is richer.
03-29-2004, 07:23 AM #5Supporting Vendor
- 11,838
- 163
- 11
- 795
Analogs
A-27 is counter C.W. to richen also..........
Jay @ JSRE
03-29-2004, 10:58 AM #6
03-29-2004, 12:37 PM #7Supporting Vendor
- 11,838
- 163
- 11
- 795
A-17
Is clockwise to richen, Markus !
Jay @ JSRE
03-29-2004, 02:20 PM #8
Clockwise
Good. Otherwise I would have been even more confused, because turning it clockwise really seemed to make the engine run richer.
Jay, you don't happen to have the sheet with the ECU test parameters for the A17, do you?Markus' Performance Boating Links:
03-30-2004, 02:18 PM #9Member
- Mar 2004
- 43
thanx for all the reply.s
so i have too turn it counterclockwise
i have heart of a choke funtion
on the old analog boxes this is going on when you start
everytime even when the engine is hot
how can i make it work with the push key function ??
greetings menno
03-30-2004, 02:52 PM #10
Push key choke
The wires are there already in the wire harness, so if they are not already connected, connect the wire that comes off the starter (I think it is yellow/black) to the wire in the key harness that is connected to the enrichment (choke) function. (I think that one is yellow/black, too)
