Results 1 to 9 of 9
Thread: Aluminum Rub Rails Clean up??
03-06-2004, 06:41 PM #1
Ok all mighty ones please pass along your great wisdom on how to clean up my rub rails.
There the same Aluminum ones that we all have, mine have a bunch of scratches in it most aren't to bad I just want to find a way to clean them up, remove some of the scratches and make them look good or better.
Help!!!!!!!!!!
03-06-2004, 06:53 PM #2
Fibre Optics
Yep, that's right!!
Old cut off end of a fibre optic cable.
6" chunk will do.
Remove outer covering. Tape it up with masking tape, start using it like a big pencil eraser.
Amazing.
There you go.52 Maritimo 2007 w C-12 CAT's
1987 Skipjack 28 - twin KAD32's
1972 Marauder - searching, searching...
1995 / 2016 Zodiac Hurricane 733 w 300 ETEC G1
1999 Regal Rush XR-2 Sport Jet
SportYak - Goin' retro...
03-06-2004, 11:30 PM #3
Thats a great idea if you've got it laying around. If not it seems pretty expensive sand paper. 6" yikes
Oh you mean length.
I haven't tried this but it might work. Get something hard like a drill bit or screw driver and use it like a burnisher. The rub rails are a fairly soft kind of aluminum and might lay back down.
Figure someone can be the guinie pig for this'90 STV
'96 260
under construction
for far too long
03-07-2004, 11:49 AM #4
Cable
One of the local polishing shops usually has surplus pieces for abou $20.00.
Try surplus or scrap dealers.52 Maritimo 2007 w C-12 CAT's
03-07-2004, 05:50 PM #5
Fibre??
Ok got the tenique but what makes it work ???
Do I need a pocket protector to go with it What the do I know about fibre optic I cann't even shut off my computer cause I have to get the neighbors kid to turn it back on. I haven't even logged off since 93
But big pencils and easers I do know about
also small buses
03-07-2004, 05:54 PM #6
03-07-2004, 07:24 PM #7
Maybe they mean someone who can't read but can write?
'90 STV
'96 260
under construction
for far too long
03-07-2004, 08:33 PM #8
Gotta read the sign to know what to do
Then following the instruction on the sign would require writing.
Rickracer
Sunshine Syndicate Member
There is a fine line between "hobby" and "mental illness."
[img]http:/
05-12-2004, 10:50 PM #9
Okay boys,
Here's the link to PPG Metal Conditioners. The DX 531 cleans like a bitch with a scrub pad. Should be cleared over.
The DX 501 actually does a good job and leaves a somewhat protective layer, better than RAW.
Actually works pretty good on the speedmaster too, especially those lovely exhaust stains
http://www.ppg.com/refinishftpsite/docs/p-226.pdfEldest Moron Brother
SOLD 95 Euroski
99 2.5 280+
Delta w/ 75 Stinger 55+
RIP RPM Racing
