Results 1 to 7 of 7
Thread: Oil bath hubs
    Sunny Ca
    Oil bath hubs
    Any one have oil bath hubs on there trailer and how often do you change the oil.Are they any good?
    1 Newbie
    Birmingham, AL
    Oil Bath Hubs
    I have them on my Triad DR-20 trailer that has been towed all over the Southeast for the past 2 racing seasons. I change the oil once a season. I am very happy with this design.
    MAKE SURE that the hub cover that holds the seals are NOT stamped steel - they leak. The bullet units do not.
    I hope this helps,
    Disclaimer: Everything I post is just my .02, and should be take only as opinion. These opinions tend to be notoriously WRONG, and any that are correct, can only be attributed to my being dropped on my head as a small child - repeatedly.
    Kissimmee, Florida
    Semi trailers that go unreal mileage use them
    I'd say that's a pretty glowing endorsement for the idea anyway.
    Rickracer
    Sunshine Syndicate Member
    There is a fine line between "hobby" and "mental illness."
    [img]http:/
    Sep 2009
    Cleveland, Ohio
    Towed my boat for 10 years without changing oil. Changed it this season everything looked new oil was still clean and no metal shavings. I believe this is the best system better than buddie bearrings
    1986 cougar mtr 21
    2003 supra launch ssv
  5. Thanks Instigator thanked for this post
    Sep 2016
    McHenry,Illinois
    I've had some good and some bad luck with them. They're great as long as they don't leak...plastic covers don't seem to last real long...have had them deteriorate and leak oil out. If you keep an eye on them and reseal when water appears you'll be fine. We've replaced most of our shop trailers with the old grease style.
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork(Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140 (current)
    Ranger 17' Aztec / Merc 115 (current)
    Hustler 16' Victor / Merc 125 (current)
    Hustler 16' Victor / JohnRude 135 (current and restored)
    Hustler 15' Family Tunnel (current project)
    Nov 2009
    Jax, Fl.
    Have had mine for the past 3 ta 4 years changed the fluid once since then. plan on tearing down and checking bearings over the winter one day. have had 0 issues so far. guys up north have to pull forward or back once or twice over the winter to keep bearing coated from what I have red. we boat year round here in Florida so no issues with that.
    South Africa
    I fill mine up with Mercury HP gear oil. No issues as yet
    I made mine with sight glasses so that you can always see the level and quality of the oil
