Results 1 to 15 of 21
02-12-2004, 10:41 AM #1
Anyone build their own setback bracket?
Have any of you guys built your own setback brackets? Got any pics? What kind of materials did you use? Thinking about building a 14" setback bracket for a Vegas.
Ian
...boatless for now.
02-12-2004, 12:08 PM #2
I built my own 8" static setback bracket.
years ago. I use aircraft quality alum channel and 3/4" for the bracing. Punched a bunch of holes in it to lighten it up. Used STN STL hardware and I think it came in at 23# when I was done. A couple more than I hoped for. I have a Bpb's hydro plate bolted to it and use 2" blocks behind that for a total of 16"
rgsauger liked this post
02-12-2004, 12:22 PM #3
Seems like a lot of bolts that could get loose or break?
JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
02-12-2004, 11:16 PM #4
Not if you use ........
good quality 1/2" x 13 bolts with lock washers and design it so no extra stress is on the bolts !!!!!!!!! (large enough flat areas to not allow any twisting or flexing) If it's designed right the only thing the bolts have to do is hold it together. I have had that bracket on now for probably 6 years now and nothing has come loose or broken. I have put it through the test in rough water also. There are two cross supports that tie the sides together. Two bolts in the end of each. I think welding would tend to crack and break with the vibrations we send to these things.
02-12-2004, 11:19 PM #5
Looks nice!
Thats really not too bad on the weight for that much setback Balzy. We have done them in 4130 Chrome Moly as well. No photos to post sorry.
03-12-2004, 11:50 PM #6
I'm thinking about building my own as well.
The aluminum angle seems pretty hard to find around here. Anybody have some large angle kicking around?Hydro Burke
AE-21
330 HP 2.5 "Monster Marles" Merc
Seebold F1 race boat
03-13-2004, 12:25 AM #7
I did this one for my 21' Eliminator Daytona
It's purpose was to eliminate the cracking that occurs at the line between the transom and the deck. Mission accomplished.
Rickracer
Sunshine Syndicate Member
There is a fine line between "hobby" and "mental illness."
[img]http:/
03-13-2004, 09:10 AM #8
you need to check out the 22 talon with twin drags for sale in the classifeds. thats a cool plate. anyone seen that set up before?
Helmut
slow boats
03-13-2004, 11:24 AM #9
If you can reduce the bolts you can reduce the weight. Take the number of bolts being planned on and weight them. They add up very quickly
'90 STV
'96 260
under construction
for far too long
03-13-2004, 03:16 PM #10
I was giving some thought to making one of these. Adds 4 1/2" of setback without a plate and is really cool looking
Hydro Burke
AE-21
03-13-2004, 03:37 PM #11Originally posted by Burke Kilgour
I was giving some thought to making one of these. Adds 4 1/2" of setback without a plate and is really cool lookingBruster's Mercury solid motor mounts, details here:
http://www.powercatboat.com/Bruster/Bruster.htmlI'm been living in fast forward, now I need to rewind real slow....
03-13-2004, 03:42 PM #12
Ya, and if you look at the front of it, it has slots for adjusting the height of it as well.........very cool.
Hydro Burke
AE-21
03-13-2004, 05:00 PM #13Originally posted by Burke Kilgour
Ya, and if you look at the front of it, it has slots for adjusting the height of it as well.........very cool.Bruster's Mercury solid motor mounts, details here:
03-20-2004, 06:49 AM #145000 RPM
- Dec 2002
- chespeake bay md
- 663
RacerRick I really like that plate Good idea.
03-20-2004, 10:17 AM #15
I thought it worked well.
Rickracer
[img]http:/
