Results 256 to 270 of 315
Thread: RC boats? lets see them!
09-09-2007, 08:51 AM #256
The length is ok with the Insane it's a little to narrow and doesn't handle rough water to great, Its not one of the best handleing boats and has taken a long time to get it to be a good handleing boat I have about a pound of weight in the front to make it stable but it stll gets a little flighty on long straights
09-09-2007, 08:58 AM #257
How wide Is Its widest point?
21' Douglas Skater
09-09-2007, 09:00 AM #258
Any of you guys members of NAMBA or IMPBA or just recreational RCers
09-09-2007, 09:02 AM #259
09-09-2007, 09:04 AM #260
Oh yeah... I am awaiting the mold back for a STV style r/c build hull. That Is for electric power at 25" and I am about 3/4 of the way done with the 40" scaled up for gas power.
21' Douglas Skater
09-09-2007, 09:39 AM #261
It is 16 inches wide another 1 to 2 inches would stable this boat right out
09-09-2007, 09:43 AM #262
09-11-2007, 06:06 PM #2636000 RPM
- Aug 2007
- Commack, Long Island NY
- 1,338
Engines are Zenoah 260 inlines stock with tuned pipes.
boat is new with 7 runs at 20 to 30 minutes per run.
I have GPS in the boat and have clocked it at 61 MPH so far.
Engines are not broke in yet and I was only using a 70 mm prop.
The hull I'm running with this engine setup needs 80 mm prop to get into the mid to high 60 MPH range.
hull is Expresscraft GTX 65" long with a 16" beam weight is around 30 pounds.
SteveLast edited by SuperBoat Steve; 09-11-2007 at 06:10 PM.
09-11-2007, 06:48 PM #264
A inch to two on the width side
10-06-2007, 02:13 PM #265
Seaducer Boats Gen2 Cat - CC Racing ProMod 260
10-06-2007, 04:27 PM #266
Davett Drag hull,Modified 260.Custom painted by RPP Hobby in Cali.Chris
10-06-2007, 05:14 PM #267
10-06-2007, 05:16 PM #268
10-07-2007, 05:36 PM #269
10-07-2007, 05:41 PM #270
What does your setup consist of? Where does it balance?
My cat is also the gen1 insane (all Insanes in my stable) and it handles awesome and runs better in the rough then my mono's do. Instead of having a bunch of weight in the nose, add some weight on the CG.
Mine with a mod zen runs high 50's and turns on a dime, and ive never had it blow over. Now with the quickdraw in it ill probably be adding a little weight to move the CG a little more foward.
