Results 1 to 14 of 14
Thread: where to buy a press??
01-26-2004, 04:12 PM #1
hey guys,
these OMC pistons are really annoying b/c the wrist pins need to be "pressed" in. im sick of whacking them with a hammer and i want to buy or make a press.
any ideas on something pretty cheap?? i was thinking of just welding up something like this..
scott"If everything's under control, you're going too slow"
-Mario Andretti-
76 vixen,.. on the back burner
82 laser comp. 380 ray
PICS OF THE VIXEN REBUILD
01-26-2004, 04:13 PM #2
4got the pic..
hers my idea (quick paint sketch)
-Mario Andretti-
01-26-2004, 04:16 PM #3
what about
a big bench vise? I got one if u wanna try.
01-26-2004, 04:17 PM #4
Re: what about
i got a bench vise also.. but it doesnt have enough room.. i need at lest 8inches i clearance (3 for piston, 3 for rod and 2 for piston cradle)
-Mario Andretti-
01-26-2004, 04:18 PM #5
Northern Hydraulic
Pretty cheap too.
01-26-2004, 04:21 PM #6
I think it will fit
in mine.
01-26-2004, 04:31 PM #7
i think this might do it..
http://www.harborfreight.com/cpi/cta...temnumber=2457
-Mario Andretti-
01-26-2004, 04:33 PM #8
Too Small
Get one that you can do bigger stuff too like a lower unit. They were about that much and bigger at Northen Hydraulic.
David
01-26-2004, 04:36 PM #9
Re: Too Small
David
-Mario Andretti-
01-26-2004, 04:42 PM #10
Bearings
All kind of bearings. Crankshaft bearings, lower units have a couple but that's on real motors I don't know about your Tyco
01-26-2004, 05:03 PM #11
01-26-2004, 05:13 PM #12
Unless you need the tons of force an arbor press is better. These are the ones with a lever geared to the pressing rod so pulling the arm down presses the stuff in or out. It's much much faster and easier too.
There are various places harbour freight, grizzly and the like. The bigger they are the higher they cost.
A large C-clamp could work if this is an infrequent use.
arbor press'90 STV
'96 260
under construction
for far too long
01-26-2004, 06:41 PM #13
YOU COULD MAKE ONE LIKE THIS
John E.
HydroStream Vandal 140 EVINRUDE 69mph GPS
Black'99 SVT Lightning #1767 of 4000
If It Ain't Blown It Sucks!
01-26-2004, 07:01 PM #14
You don't need a press to put them together...
Warm the pistons under a heat lamp (Home Depot), and put your pin in the freezer for about a half an hour to an hour. They will slip right in with finger pressure only.
Rickracer
Sunshine Syndicate Member
There is a fine line between "hobby" and "mental illness."
[img]http:/
