Results 1 to 9 of 9
    Atl. Ga
    Stock Chopper Verses Cut Chopper Differences??
    What kind of performance differences can I expect from each.
    I have run a stock 28p Chopper before.
    Thanks, Dana
    May 2001
    In the Hills
    in my experience which is not very vast on props, the stock 26 prop slipped more in the hole shot so i put more cup at the tip and into the leading edge of the tip and cut the weed cutters off and squared up that area to look more like the cut prop i have which is a hoss triton 30 which bites better, and now the 26 does also, i may be wrong but the squared part of each blade on the leading edge at the base of the hub by the thrust washer grabs the water better than the smooth sweep of the stock one, at least i found this to be some thing to stop my stock one from slipping as much.
    hope this helped a little,
    skip
    Sunshine Syndicate Facebook link...
    https://www.facebook.com/pages/Sunsh...ref=ts&fref=ts
    Atl. Ga
    But if you look at this Photo, You will see the ET has the straighter edge of the blade on the top. Kind of like a Cleaver.
    May 2001
    In the Hills
    ya thats a prop for top end i believe, hang tight some of the experienced prop guys can give us insight on this stuff so we can both learn, god knows i need some edge-of-a-cation on props
    good thread for info, skip
    Atl. Ga
    Unhappy No Help
    Well I guess there is no Prop school for this week Talon.
    Damn, I guess am going to have to buy one of each and try them out myself.
    May 2001
    In the Hills
    nah, they are just SCARED to spill the beans i guess
    maybe it's the beers talking
    c'mon i know some body can help this man!!!!!!
    step up, skip
    cut chopper
    The cut chopper was designed for the Allison. Call Bill Eves at Performance propellor at Soddy-Daisy TN. He makes them and will custom tune them to each boat.
    CC
    May 2001
    Nashville
    Rule1,
    The Allison Cut Chopper will out accerlate the Stock chopper. It will not feel as stable as the stock chopper. Top end is pretty close. I have a 26 and 28 Allison Cut chopper from Performance Prop. Both Tim and Billy have been VERY good about making small adjustments. I Saw a Post on the Allison board where you run a 26 trophy. The 26 Allison will come out of the hole MUCH harder. I like the Allison cut Better than the ET for Acceleration. If you would like more info leave me an email Address.
    Tim or Billy at Performance Prop can fix you up.
    Kissimmee, Florida
    Cool Hi Dana
    You might want to call Kevin at R&R Propshop too, everything I have seen by him is fantastic.
    Rickracer
    Sunshine Syndicate Member
    There is a fine line between "hobby" and "mental illness."
    [img]http:/
  10. Likes KIRCHNER liked this post
