Results 1 to 15 of 41
Thread: 2.0 150HP vs. 2.5 150HP
12-08-2003, 12:34 PM #15000 RPM
- May 2001
- Maine
- 983
- 35
- 43
- 171
Any idea what the speed difference would be between a 2.0L 150 HP & a 2.5L 150 HP on the same boat. I assume more cc's, more torque, bigger pitch prop at same RPMs = more speed. Any idea what to expcet on the speed end? Boat is a 18'6'' Baja that has a hull alone weight if 1,400 lbs...Gear & Driver est 1,800 lbs. Both weights are w/o motor.
12-09-2003, 05:59 AM #2
2.0 VS 2.5
Don't waste you time with the 2.0 no balls,I've got a SST-120 motor which is a race verion of the 2.0 with 26cc heads,a stock XR6-150 2.5 liter on the same boat will pull me 4 boat lenths to 60 mph,and the sst 120 is 180 hp,the sst will out run the xr6 on the top side but its 180 hp John LIGHTNING POWER BOATS
12-09-2003, 12:23 PM #3
I believe Viper Ronnie started out with a 2.5 150 and with a little (okay, a lot) of grinding and porting, etc, it made a lot of power. A lot.
12-09-2003, 03:19 PM #46000 RPM
- Oct 2002
- Dallas
- 1,520
4speed...
you and the Baja will be much better off with the 2.5.
To answer your question, technically there should be no real speed difference between two motors with the same HP...150 hp is a 150 hp regardless how you slice it. If you prop to peak HP, both motors might use a different props but the end result would be the same speed.
One thing that would be different is how quickly each motor hit it's top speed...the 2.5 would get there a lot sooner.
12-09-2003, 04:24 PM #5
Are we saying that boats are the same as street cars,there is no substatute for cubic inches?
12-09-2003, 04:37 PM #6
Re: 4speed...
One thing that would be different is how quickly each motor hit it's top speed...the 2.5 would get there a lot sooner.> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
12-09-2003, 05:16 PM #76000 RPM
- Oct 2002
- Dallas
- 1,520
1BadStream:
Peak HP...not peak torque is what determines top speed...if both engine produce the same HP (150) they will produce similar top end numbers regardless of its size.
Torque is a good indication of how quickly top speed will be reached and no one props a boat to peak torque.
A 150 hp 2.0, 2.4, 2.5 and 3.0 litre engine (assuming equal weight) will all produce equal top end numbers.
12-09-2003, 10:12 PM #8Peak HP...not peak torque is what determines top speed...if both engine produce the same HP (150) they will produce similar top end numbers regardless of its size.> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
12-09-2003, 11:58 PM #96000 RPM
- Oct 2002
- Dallas
- 1,520
Stream...
What do you think weighs more 150 lbs. of feathers or 150 lbs. of bricks?
If you said they both weigh the same then we're getting somewhere...
Two engines producing the same HP will mathematically and by the laws of physics produce equal top end numbers...regardless of what kind of torque they produce.
Obviously a motor with more torque will get the job done faster...but both motors will end up giving you the same top end numbers...there is nothing else to argue about.
Your 2.5 litre engine was faster than the 2.0 because it produced more HP...and I don't even have to put it on a dyno to prove that point.
I don't want to confuse 4speed...let at least agree that a 2.5 is a better all around engine for his Baja...
Sok2807 thanked for this post
12-10-2003, 04:02 PM #10
4-speed
okay...if I may comment. The 2.5 is better and a 3.0 is even better. It really depends on your budget. The question really is how much do you want to spend?
A 150hp 2.0 XR2 in nice condition will run about $2000.00 and in my opinion is the best "bang for the buck" . The XR2 uses alot of the 200hp parts and is a more robust engine than a rugular 150hp. (XR2 is important!)
If you get to a 2.5 litre your going to be twice that.
I am interested in who is right...Reese or 1badstream. I see both points. I know in race cars, torque is key to winning races but it is not because of a top end differences but because you can accelerate out of the corners better.
I dont know enough to comment about the torque v. pitch question.Last edited by Glowone; 12-10-2003 at 04:04 PM.
Jason
Toledo, OH
12-10-2003, 04:05 PM #11
There is no replacement for displacement
So I have found.
The Reverend, (Cedar Machine Service on Facebook)
1989 HST 2.5 260 Merc Offshore
1991 Vaserette YT 200 Mercury
1988 Venus XT 200 Yamaha
1983 Viper II Merc 90
1977 Viper
Mini GT tunnel, 25 Merc
"African Queen" pontoon 25 Merc
Aluma fishin tub, 20 motors to choose from!
GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
12-10-2003, 05:18 PM #126000 RPM
- Jul 2002
- Minneapolis, MN
- 1,717
Well.... Actually you'd have to lay the torque curves next to each other. Most likely the 2.5 is gonna make more torque, but if they make the same horsepower (do they?) they would have an equal top speed if they could both be propped appropriately....I have no idea where the power peak is for either engine, but since HP=Torque @ 5250 rpm, and these fishing motors probably make peak horsepower before 6000 rpm, they're probably close in peak torque too... Yea, the 2.5 probably has more at lower RPM -- hence the edge in accelleration -- but with the correct prop, they should be awful close in top end..
Currently involved in activity that can only break one piston at a time......
12-10-2003, 07:48 PM #13
The issue is, two different engines with a 150 Hp "rating". The manufacturers are allowed a substantial variance in true HP while still maintaining the HP rating. I have to think that on the dyno, the 2.5 makes more real horsepower.
12-10-2003, 08:09 PM #146000 RPM
- Oct 2002
- Dallas
- 1,520
Not only...
did the manufacturers use a pretty wide variance, they also had years where the HP figures were Crankshaft vs. Prop Shaft.
Regardless of the HP rating there is no doubt that the 2.5 had much better torque as well. In either case the 2.5 is a substantially better engine for this application compared to the 2.0.
BTW...a used 2.5 is pretty damn cheap.
12-10-2003, 10:22 PM #155000 RPM
- May 2003
- Grafton, WI
- 285
- 40
- 171
Reese...
you have the patients of a saint.
Any fool can make something complicated - it takes a genius to make it simple.
