Results 16 to 30 of 167
Thread: who has the fastest Laser LTV?
11-06-2003, 03:42 PM #16
sweet!!
Damn, Nat that thing is going to look sweet yellow, post some more pics as you go. Matt
11-06-2003, 04:45 PM #17
oldstv is on the money!
I plan on changing over to a 15" mid in the future.
11-06-2003, 05:08 PM #18
Best speed
I hit 91.7 mph in my dad's (POP-O_826) Laser LTV... And it"s a Fishin' boat, that was rigged to fish... Two batteries, all the polls the rod box could hold, and a trolling motor....
It's got an 86 2.4, built by Jon Wright, it now has stock heads on it, but is a little stronger with the 26cc's....03 Sharpe 16' X 82' Houseboat
03 SeaDoo GTX 4tec (SOLD)
03 SeaDoo GTI LE RFI (SOLD)
93 Mirage RR Merc 2.5 (SOLD)
86 Laser LTV Merc 2.4 BP (built by tinker060 may he R.I.P [SOLD])
11 26' Tunnel with a Merc. 115hp a.k.a. a pontoon (Man, gotten old)
11-06-2003, 07:49 PM #19
Here is a pic of the boat when it was still side steer....oldschoolltv, I saw your boat from a distance at the Blowout, but I would have liked to see it up close. In fact, if anyone has any pics of their LTVs, running or on the trailer, I would really like to see them!
11-06-2003, 08:49 PM #20
Pics?
11-06-2003, 08:51 PM #21
and some more pics.
11-06-2003, 09:02 PM #22
Thanks man!! I cant wait to have some pics of mine in the water ! I like the way the boat looks in all white.
11-06-2003, 09:07 PM #23
Motor height
How hi above the pad do you run yours, Brian? I've been telling dad," it's too low", I feel it could come up at least a 1/4" or more..
His has all kinds of bow lift, I also know that the prop he's running can cause that, but I been looking at your pics, and those motors look higher....
If you have time, let me know.......03 Sharpe 16' X 82' Houseboat
11-06-2003, 11:00 PM #24
nat ive seen oldstv's boat that thing is sweet,very clean,you ned to see james's laser up close.hell when i had your boat i didnt like parking next to the damm thing.
02 mirage ski racer w/ 2.5
lake tarpon (LTB racing)
"Mirage Boats... often imitated but never duplicated"
11-07-2003, 08:34 AM #25
cool pics
Man I like seeing all these pics it gives me ideas on how I want to make my rear seat, maybe someday I can get some running shots, also I was wondering how that whale tail on the yellow boat works, I was considering some type of foil for mine, for cruising under 30mph it likes to porpoise some unless you trim it all the way under. hope I get to see all these in person, Nat it looks like it is coming along good. Matt
11-07-2003, 09:09 AM #26Platinum Team Member
- Sep 2002
- Thomasville Ga.
- 1,547
There are a lot of factors that must be considered when you talk about how high to run you motor. Your boat will like the nose cone above the transom when running mid to top end. It will not leave as hard there. You must have your gear case in good shape. If you don't you will have blow out problems. Mine is three boats in one, everything below 90mph. Another from 90-100. And still another after 100mph. Get a prop with as much transom lift as you have bow lift. You want the boat to run as flat as possible. Making sure the whole boat is out of the water. Gene as Remco has a lot of experience with these boats, he could build you a prop that will work. The boats are like any other, weight has a lot to do with the way they feel. A hydraulic jack plate will help you find the right spot, they can be adjusted while running. You can get one from T&R marine in Perry Fl. You want a 5" offset. Be sure to be safe and try only one thing at a time.
11-07-2003, 09:27 AM #27
SOUNDS GOOD
Laser sent this prop to us, we've tried many since 86, and always go back to it.... At mid-range it porposes alot, but on top end is very stable....
Actually, I like driving it, better than my Mirage.... I know there's some left, take everthing off it and we might see 95.... But to be going on it 14th year with no rebuild, it's impressive....
THX03 Sharpe 16' X 82' Houseboat
11-07-2003, 09:40 AM #28Platinum Team Member
- Sep 2002
- Thomasville Ga.
- 1,547
Yep thats a good place to be.
I only drag race with mine. Don't care for top-end running. If I can figure out how to get picutres from one post to another I will post one of mine.
11-07-2003, 12:01 PM #29
Here ya go Scott.
Not the best in the world but.....
Smith's Bend Scoundrel
'88/'11 Reaction 19, '88 Merc 200 "Jus' Toodlin'"
'83 Hydrostream Varmint, '88 Merc 200 "Jus Triflin'"
11-07-2003, 12:02 PM #30
anudda
