Results 1 to 15 of 20
08-28-2003, 04:31 PM #1
New prop doesn't fit - trim tab is in the way
I bought a new prop this morning for my '74 150hp inline 6 mercury outboard. Went from 19 pitch to 21. Now the damn thing doesn't fit...the trim tab is in the way! What do I do? Do they make different size trim tabs or something?
08-28-2003, 04:56 PM #25000 RPM
- Courtice, Ontario, Canada
- 980
You can get a flat one without the tab or just saw your tab off. I don't think they really do much anyways except for corrosion control.
1996 Allison GSE /200XS
1977 Hydrostream Ventura / 150 Mariner MAG III
08-28-2003, 05:04 PM #3
I'm glad you said that...I just spent the last half hour cutting it off. Now I've got a different problem...the inner round part of the prop...the cylinder that the blades attach to...is to long. When I tighten down the prop nut it won't spin, because it is too tight. Is this the wrong prop?!?
08-28-2003, 05:28 PM #45000 RPM
- Aug 2002
- New England/MA & NH mostly
- 668
HEY ZMOZ...You need a different thrust washer by the sound of it...If you know what type of prop it is, post it & I'll bet one of the gurus here will probably be able to give you the part number you need to make it work...These guyz know their ****e... ...
>> IF YOU'RE GONNA RUN WITH THE PACK...YOU CAN'T PISS LIKE A PUPPY !!!<<
08-28-2003, 05:35 PM #55000 RPM
- Mar 2002
- Seaford NY
- 713
prop problem
try the thrust hub from the old prop bet you have the same problem I just had on a old outdrive the new thrust hub is thin and fit's on a tapered shaft the old style has a much longer thrust hub with a square sholder and using the new one let's the prop go back too far and hit the carrier cover cap the old hub should work your problay using a new flow torq 2 hub.
jon b
08-28-2003, 05:58 PM #6
I tried the washer from a different prop - I don't know what it was from but it came with the boat. It was much thicker, and I thought it would work, but when I tightened the nut down it was still too tight. I think the problem is that the old prop would go inside of the lower unit a little bit, the newer prop has a bigger diameter and does not go in. Did I get the wrong prop?
08-28-2003, 06:25 PM #7
What is the diameter of the gear case?
MarkHP>
1989 Canadian Edition Vista/135 Optimax
08-28-2003, 06:28 PM #8Originally posted by MarkHP
08-28-2003, 06:35 PM #9
Is the prop binding on the inside edge of the gearcase or the back face of the prop/gearcase. If it is the inside of the gearcase where the pop fits check for nicks and dents. If it is the back face then the thrust washer is too rhin for the prop.
MarkHP>
08-28-2003, 06:38 PM #10
I had a similar thing happen when I got a new prop. The thrustwasher was just a little too thin , about 1/16th inch. I added shim washer and all was fine. I was fortunate that the shim washer was splined otherwise it may rotate and cause wear on the thrust washer.
MarkHP>
08-28-2003, 06:43 PM #11
I guess I should read your post a little closer. you say the new prop is not going into the gearcase and the old one did a little. What is the diameter of the two props where they go into the gearcase?
MarkHP>
08-28-2003, 07:00 PM #12Originally posted by MarkHP
08-28-2003, 07:22 PM #13
Yup. That's it you have the wron prop. The new one is for a 4 1/4" gearcase. Measure your gearcase where the prop fits in, this is the size you need, usually a 3 1/2". Where did you get the prop?
MarkHP>
08-28-2003, 07:24 PM #14
I got it at a local Merc dealer. Dumbasses!
Thanks everyone...
08-28-2003, 08:52 PM #15
MarkHP, your rig sounds familiar. Isn't there a picture of it on the HS registry?
