Results 16 to 30 of 43
    Dec 2008
    chino
    Those are cleavers so it’s most likely not your prop. It doesn’t take much trim at all to fly these things. Start with the trim all the way down and speed the hull up as much as it will go then one little bump at a time raise the trim until it breaks free. You’ll feel it almost suddenly loosen up. If you trim too high it will be all over the place. Sometimes at lower speeds you can trim quite high and it will cruise nice but once you throttle up it will be too hairy. At high speeds it doesn’t take much trim to fly good. That thing should pull 100+ when it’s all sorted out. Seat time is the best education. Don’t be reckless be sure you and all passengers wear a lifeline safety vest when going fast. Just be careful. Skaters are known to be pretty solid safe hulls but too much air underneath any speedboat is risky as heck so take your time getting used to it. The downside of speedboats is you typically don’t get tons of time at high speeds to learn all this. It takes many runs to get it second nature. Have fun
    Sounds good.
    Thank you Sir for the input.
  2. Likes LakeFever liked this post
  3. #17
    Jul 2002
    Hey Turd,
    Legend Jim Speros got a hold of me and he is sending my contact info to you. I have a vaca house in Havasu. Let me take a look at it, I should be able to help.
    Thanks
    Tony Cafiero
  4. Likes LakeFever, NICE PAIR liked this post
  5. #18
    Feb 2011
    HUDSON, FLORIDA
    im following this thread closely, iv just about given uo withthe porposing skater[skaters], ive tryed everything, 75lbs in the nose,turn buckle typp tabs,6 types of props,bow lift,stern lift,thru-hub o/h, 3bld.4 blade motor up,motor down,in,out ya ya ya. only ONCE did i get past the hop to about 80. could never do it again around 50 -60 i trim up, im flying, any faster is crazy. trim in does not help &nim too old to stay in it. Artk the center pod model ifeels better than the tunnel, still porposes also. dunn know
  6. #19
    Aug 2015
    Southeast
    Check the last 3-5 feet of the bottom on each sponson to make sure it's flat. Use a straightedge of some sort to check.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship" Sold
    Blazer 650 Pro Tour
    30ft Cobra with Triple 280's
  7. Likes floatn turd, Jimboat liked this post
  8. #20
    Dec 2008
    chino
    Quote Originally Posted by trbocharge View Post
    Hey Turd,
    Hi Trbocharge,
    Thank you for the help.
    I don't know if I'll be taking that boat out to Havasu anymore this year. But
    If and when I do, I will message you and see if you have the time.
    Thank you Sir
  9. #21
    Dec 2008
    chino
    Quote Originally Posted by KIRCHNER View Post
    Hi,
    Do you have a 21ft with twins as well?
    If so, that is the exact information I am looking for.
    Thank you
  10. #22
    Feb 2011
    HUDSON, FLORIDA
    i have 2 steps to deal with, 1 about 18'' foward, then another foward of that. look straight and rock solid. another 80 hp would do the trick,get me to 75 quick.ive read all theboating tests, back in the early 80s, no mention of porposing what so ever, think a little pay-ola was goin on, at the tests? tests was with a 200. the non-s model does the same. maybe a 20'' mid, flat on the transom would run flat. canada used them for patrol boats.
  11. #23
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by floatn turd View Post
    Hi,
    Thank you
    no, i have 2 18 and 18s, restored, orig teak trim.seadek floors, nice. calm water is the worst,mine like it choppy
  12. Likes floatn turd liked this post
  13. #24
    Feb 2003
    peoria il
    A guy around me had one with twins same problem he installed a K plane in the center.
    Helped till he got it up and going.
  14. #25
    Sep 2012
    When my 21 Lightning had twins before I had it there was a big tunnel tab in the middle
  15. #26
    Board members Alamo Dan and Warlock Dave have both had multiple 21 Skaters (twins and singles). They are both knowledgeable guys.
    Mar 2022
    Lake Travis Texas
    While I was airing out my 28 today I thought of this thread. I had my 14 degree overhubs on in flat water. At 70 mph it porpoises. There is no trim position that will make it stop. At 80 mph and up there is no trim position that it will even suggest a lope or porpoise. I either cruise slower then 60 or no slower then 80. Most often I cruise at 90 or 100. She just loves going 100 mph. She's god awful, miserable at 70 with that set of props.
    Jim
  17. Likes NICE PAIR liked this post
  18. #28
    Feb 2011
    HUDSON, FLORIDA
    my 2 18s act the same, above 70 nothing will stop porpoise, i have to cruise at 55 or try to get it to 75+, if its choppy enough' they cant touch my magnolia cat 15' /w 2.5. no porpoise at any speed, just flys at 80 n cruises at 30. and all the wieght is in the back. 1962 hull design/750 lbs.
  19. #29
    Mar 2022
    Lake Travis Texas
    The 14 degree are stern lifting. Got them for summer and rough water and they shine in that role. Now that the weather is cooler and summer traffic is gone my 18 degree thru hubs work best. I am gonna put them on tomorrow. They barely lope at all , can't remember for sure but I think it tries to at 60. I haven't run them this year and don't remember details but, I will report back.
    Jim
  20. Thanks KIRCHNER thanked for this post
  21. #30
    Feb 2011
    HUDSON, FLORIDA
    im gonna take out my s model tomorrow running a sig drag4 o/h, try to get past porpoise zone once again, jacked up super high w/ hull intake. the d4 seems to be a low rake prop.
  1. 21ft skater, trick, or extreme
    By Travism in forum Hulls Wanted
    Last Post: 07-06-2020, 03:46 PM
  2. 24 Skater questions
    By Sea2jet in forum General Boating Discussion
    Last Post: 11-21-2015, 02:59 PM
  3. Skater 28 Questions
    By mikesufka in forum General Boating Discussion
    Last Post: 09-03-2015, 08:08 AM
  4. 21ft Skater
    By PHISH in forum General Boating Discussion
    Last Post: 01-23-2006, 04:54 PM
  5. 21' Skater questions
    By AlaskaStreamin in forum General Boating Discussion
    Last Post: 02-04-2004, 08:04 AM
