Results 1 to 6 of 6
08-01-2025, 12:37 PM #1
5000 RPM
- Nov 2004
- South Haven, MN
- 139
1986 V-King/2.4 200 Merc set-up? Blowing out....any experienced V-King guys out there
At around 79-80mph my 2.4 200 Merc, with a stock gearcase is blowing out. I'm turning a 26" pitch in-line chopper 5800-6000rpms, the 200 is mounted on a Bobs 5-1/2" jackplate, and it's raised 4-1/2" above the top of the transom. Short of getting a nose-coned gearcase...are there anything else I could try to keep from blowing out? Lowering the motor down??? Any ideas? thanks.
rjdubiel liked this post
08-01-2025, 01:36 PM #2
A torque tamer mounted to the skeg might help. Raising the engine, and installing a transom mount water pick up might also help. Be careful Boss!
08-02-2025, 11:30 AM #3
Put a cone on it as well as a torque tab. Just trust me it’s 100% the correct thing to do unless you like really dangerous situations
08-02-2025, 02:04 PM #4
08-03-2025, 11:50 AM #5
I had the same issue until I changed props. Can't tell you what I changed to cuz it was 45 years ago and I can barely remember what I had for breakfast. Cone and torque tab are also essential at that speed.
RockTeam Junk
08-04-2025, 01:13 AM #6
80 mph is right about the limit of a stock gearcase. You are going to need a cone. Height above the transom doesn't matter. Height of propshaft to pad is what matters. A big ear chopper will probably work better than an inline chopper.
1986 V-King 1988 Merc 200 questions...
By dpf-01 in forum Technical DiscussionReplies: 3Last Post: 09-06-2024, 04:38 PM -
1986 Hydrostream V-king, Pad-V
By Iceout in forum Hulls up to 20'Replies: 1Last Post: 07-18-2014, 08:14 AM -
For you V-King guys
By Motion35 in forum Ebay Listings and Other Internet ListingsReplies: 2Last Post: 03-05-2014, 10:15 PM -
Its Good To be the King (future King)..
By Fish in forum The Scream And Fly LoungeReplies: 9Last Post: 04-18-2008, 12:10 PM -
1986 hydrostream V-King
By air_jigger in forum General Boating DiscussionReplies: 4Last Post: 01-27-2004, 06:49 PM
