Results 31 to 45 of 64
Thread: Single ram steering arm
06-19-2025, 10:54 AM #31
Team Member
- May 2009
- 2,299
- 706
- 136
- 918
- 524
- 7 Post(s)
Just as a data point, I have a three-ram clamp, that had a skinny arm tiller. Don't know if it came that way stock, I think it did. Just this off-season, I replace the skinny arm with a fattie. It was a direct replacement. Easy peasy. Maybe it was easy because I started with a triple ram?
1986 (or was it 1987?) three ram clamp.
-PeterLast edited by pcrussell50; 06-19-2025 at 01:00 PM.
"padded wonder"
__________
the wet:
18’ Bahner bow rider, 2.4/200
the dry:
2003 bmw ///M5
and a handful of clunkers
06-19-2025, 11:23 AM #32
06-19-2025, 01:02 PM #33
Team Member
- May 2009
- 2,299
- 706
- 136
- 918
- 524
- 7 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
06-19-2025, 09:54 PM #34
Well i broke out the fat arm earlier and the plug welds are almost impossible to drill lol. I ended up using masonry bits to get thru it. So I stopped and pondered on it, Ill get other plug weld drilled thru but im not 100% sure I wanna try press arm off shaft, I may take it somewhere to have it milled down also. And Im sticking with 1 7/16ths , I was able check measurements today also, not that I was doubting you. But on the other hand im thinkin I can heat the arm where id be cutting and press shaft out pretty easy , cut it and reheat arm and freeze shaft and reinstall with new plug welds
06-20-2025, 09:46 AM #35
OK Good glad u doubled checked the measurements, I will get back here once I have it milled down, seems a lot easier than drilling it out and or pressing off, I like to do things myself so I get why u are trying to do that, I hate to give this to someone else to fix
06-20-2025, 11:22 AM #36
Team Member
- May 2009
- 2,299
- 706
- 136
- 918
- 524
- 7 Post(s)
All this talk about measuring… When I swapped the skinny tiller out of my 1987 three-ram, for a fat tiller back into the same three-ram, I didn’t measure anything. Didn’t even cross my mind to measure anything. I just assumed it would fit. Wondering if I just got lucky. :shrugs:
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
06-20-2025, 12:21 PM #37
pcrussell50 thanked for this post
pcrussell50 liked this post
06-20-2025, 03:02 PM #38
ya so I brought the arm to two machinists today and one said was too big for his lathe or his tool couldn’t slide over far enough, the other said he might try it somehow but both said I should press the arm off to make it easier, issue is my arms are welded on the top
the guy that said he try it wants like $200 per arm so maybe I’ll try a hack saw
06-21-2025, 05:41 AM #39
Thinking out loud here might make a miter jig for my 4” grinder using a flush cut disc and some shaft collars to spin the arm while I push down on the grinder…cut needs to be approx 15/32” all the way around, then maybe hack up the “loose” pieces n chisel off ?????????
06-21-2025, 08:20 AM #40
Getting any of them apart is easy. The harder part is proper length and rotational alignment. The best tiller arm to use is the late model 3.0L. It's stainless steel, but the collar needs to be milled down to 1.00" tall and the upper mount holes need to be drilled out to .500 from 12mm. If you can deal with that, you'll find that the three front holes are usually in excellent condition .. and it won't leave orange streaks in your driveway ..
NICE PAIR liked this post
06-22-2025, 01:23 PM #41
There he is !!
So is the arm press fit onto the shaft?
Exactly the stainless arms are very nice too bad it took them 15 years to think of that one
06-22-2025, 01:43 PM #42
Yes
06-25-2025, 02:53 PM #43
Chaz that work looks great n all but what about the redneck engineering way of doing it if someone (like me) doesnt have all the tools n equipment
06-25-2025, 04:27 PM #44
Aaron, I thought the way i did it was the redneck way. (one at a time)
No tellin how many the factory can do in an hour.
I made a pretty simple mandrel for my press to get em apart. An alignment jig for puttin it back together straight .. gotta have at least that stuff or it ain't gonna happen. Then you need to weld it so it won't move once your done ...
07-01-2025, 09:59 AM #45
I modified a stainless 3L fat tiller arm to fit in my single ram setup. Not sure if a 2.5L fat tiller arm is the same.
I needed help from friends as I didn't have all the proper tools (who has a lathe that big
Here is the thread https://www.screamandfly.com/showthr...fshore-bracket
Aaronhl thanked for this post
Marine Machine steering for 2.5 ROS (single)
By 1BadAction in forum Misc. Parts and AccessoriesReplies: 7Last Post: 09-10-2013, 10:49 PM -
Single Cable Steering / 150 hp Pro V
By roosta~tail in forum General Boating DiscussionReplies: 2Last Post: 05-12-2011, 03:05 PM -
Single Cable Steering ?
By JLHTEC in forum Props, Setup, and RiggingReplies: 10Last Post: 03-19-2009, 07:42 PM
