Results 1 to 2 of 2
Thread: Lift pump ?
    TN
    Lift pump ?
    Lift pump ain’t working. It has a new eBay kit. How much pressure should I get on the tube going to pump? It blows air while cranking but I can easily stop it with my finger. Compression is 110-120.
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by mercrazy View Post
    make sure the gasket isnt squeezed over that hole. happens if you over-tighten, hold the diaphram up to a light source, 2-3 lbs out pressure.
  3. Thanks mercrazy thanked for this post
  1. Lift Pump Question on Evinrude DI
    By svfetter in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-30-2018, 11:01 AM
  2. etec 225 lift pump
    By derpid in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-31-2017, 12:10 AM
  3. Mercury fuel pump lift power?
    By s10gto in forum Technical Discussion
    Last Post: 06-19-2015, 06:09 PM
  4. yamaha 4 stroke lift pump failure
    By sodibc in forum Technical Discussion
    Last Post: 07-20-2010, 04:47 PM
  5. Can a Holly Red be used as a lift pump for 260 efi??
    By twig in forum Technical Discussion
    Last Post: 08-09-2009, 04:31 PM
