Results 1 to 14 of 14
    May 2009
    the netherlands
    Mercury F1 indentification
    We have here an mercury F1 engine we want to know if it is a 2.0 or 2.4 or 2.5 ?
    What year would it be?
    i,m sure Someone can tell here
    thank triplestrokerClick image for larger version.
    Jan 2020
    Pittsburg, Ca
    Mid and lower are from an OLD 2.0 or 2.4. Powerhead looks like a mix of parts but is likely 2.5L in displacement because it has dowel pins in the heads.
    Celina, Ohio
    It's an old 6 bolt mid.
    39 Post(s)
    6 Bolt Vertical Adjustment
    Quote Originally Posted by largecar91 View Post
    It has the old style mechanical swivel pin adjustment feature.
    TX......somewhere?
    power head could be a 2.0 also.. it looks ta be intact (except oiler delete + heads) fishing motor ph... should be a build date stamp on it and jus maybe a serial number on tha case half..... tha rest is what "largecar" says...
    May 2009
    the netherlands
    ok thank you we Will try to find some numbers
    May 2009
    the netherlands
    Quote Originally Posted by WaterZebra View Post
    ok is this good or bad? When did they stop making this ? I guess it must be end 70s or low 80s
    39 Post(s)
    Hydraulic Up / Down
    Quote Originally Posted by triplestroker View Post
    Powered hydraulic up / down adjustment came out in the early 90s. There's nothing wrong with a manual system. You just use a socket and crank spinner. Powered hydraulic systems came in handy for testing and rigging but were seldom changed during a race unless the water conditions changed radically or hull handling got really squirrelly. Sometimes you can have all these features (trim, up / down height and selection of props to change) and if you mess with them all at once, you won't be able to figure out a good combination. Your gearcase is a very old style SSM and props that fit that gearcase are getting hard to find.
    ...is that a oiler blockoff plate i see? if so, its a 1983-84 & up block. i don't know anymore these days, its been a long time, lol......
  12. #12
    TX......somewhere?
    it is, but '91 or better.. "fat block", wmh's without tha pump but has pump casting are '92/'93 up...
  13. #13
    May 2009
    the netherlands
ID:	542894Click image for larger version.
    only find this number
  14. #14
    TX......somewhere?
    look at tha area of base of #2 on tha block half.. kinda behind tha bend in tha advance arm... will be a m/d/yr date stamp in 1/8" numbers.. may be hard ta read and/or find but its there...
    one is hard ta find tha other is easy.....
  1. Need help with carb indentification
    By faster_daddy_faster in forum Technical Discussion
    Last Post: 03-04-2004, 11:13 PM
