Results 1 to 14 of 14
Thread: Mercury F1 indentification
05-15-2025, 11:10 AM #1
Junior Member
- May 2009
- the netherlands
- 13
05-15-2025, 11:35 AM #2
Mid and lower are from an OLD 2.0 or 2.4. Powerhead looks like a mix of parts but is likely 2.5L in displacement because it has dowel pins in the heads.
05-15-2025, 12:22 PM #3
It's an old 6 bolt mid.
05-15-2025, 02:43 PM #4
6000 RPM
- Nov 2006
- 1,644
- 14
- 168
- 77
- 725
- 39 Post(s)
05-15-2025, 03:40 PM #5
power head could be a 2.0 also.. it looks ta be intact (except oiler delete + heads) fishing motor ph... should be a build date stamp on it and jus maybe a serial number on tha case half..... tha rest is what "largecar" says...
05-15-2025, 04:00 PM #6
Junior Member
- May 2009
- the netherlands
- 13
05-15-2025, 04:04 PM #7
Junior Member
- May 2009
- the netherlands
- 13
05-15-2025, 05:57 PM #8
6000 RPM
- Nov 2006
- 1,644
- 14
- 168
- 77
- 725
- 39 Post(s)
Hydraulic Up / Down
Powered hydraulic up / down adjustment came out in the early 90s. There's nothing wrong with a manual system. You just use a socket and crank spinner. Powered hydraulic systems came in handy for testing and rigging but were seldom changed during a race unless the water conditions changed radically or hull handling got really squirrelly. Sometimes you can have all these features (trim, up / down height and selection of props to change) and if you mess with them all at once, you won't be able to figure out a good combination. Your gearcase is a very old style SSM and props that fit that gearcase are getting hard to find.
05-15-2025, 06:45 PM #9
The Historic Photo Master
- Jan 2004
- Florida
- 38,326
- 75
- 1731
- 370
- 20078
- 4 Post(s)
05-15-2025, 06:46 PM #10
- Jan 2004
- Florida
- 38,326
- 75
- 1731
- 370
- 20078
- 4 Post(s)
05-15-2025, 06:50 PM #11
- Jan 2004
- Florida
- 38,326
- 75
- 1731
- 370
- 20078
- 4 Post(s)
...is that a oiler blockoff plate i see? if so, its a 1983-84 & up block. i don't know anymore these days, its been a long time, lol...
05-15-2025, 08:04 PM #12
it is, but '91 or better.. "fat block", wmh's without tha pump but has pump casting are '92/'93 up...
05-19-2025, 03:19 PM #13
Junior Member
- May 2009
- the netherlands
- 13
05-19-2025, 03:55 PM #14
look at tha area of base of #2 on tha block half.. kinda behind tha bend in tha advance arm... will be a m/d/yr date stamp in 1/8" numbers.. may be hard ta read and/or find but its there...
one is hard ta find tha other is easy.....Last edited by tlwjkw; 05-19-2025 at 03:58 PM.
Need help with carb indentification
By faster_daddy_faster in forum Technical DiscussionReplies: 3Last Post: 03-04-2004, 11:13 PM
