Results 1 to 3 of 3
05-15-2025, 12:24 AM #1
New Member
- Sep 2024
- Perrinton, Michigan
1978 checkmate predictor s 16' set up and rigging
Parts I have
Motor 1989 mercury 150 xr4
1. 2 hole Mercury CLE coned 2.0-1 gear ratio
2.cmc power lift 5 1/2 inch hydraulic jack plate
3. hot foot
4. trim levers
5. hydraulic steering
seeking some help on set up seeking top speed and handling
what prop ?
do I need more setback?
Etc.
transom seems solid also any ideas on just beefing it up a bit
just bought the boat tried becoming member of checkmate-boats but seems impossible
thanks for the help
Dakota
05-15-2025, 03:00 PM #2
Welcome.
Sounds like' you have some decent stuff for setting up your boat.
I'm not familiar with your hull, so this will be generic info. Hopefully someone that has some first hand knowledge with your boat will come forward.
In order to optimize a coned lower, typically the propshaft would be near flush to the bottom of the boat. This usually requires a propeller in the range of 26-28p to maintain the correct rpm range for a fishing engine. Props like a merc chopper, or mazco re might get you in the ballpark.
I would think that 6" to 8" of setback would be a good place to start.
As for the transom, typically knee braces are a good idea if you dont have them.
05-15-2025, 05:02 PM #3
New Member
- Sep 2024
thanks
OnPad liked this post
Checkmate Predictor
By Ohiohydro in forum Fiberglass and Composites DiscussionReplies: 34Last Post: 05-24-2020, 02:16 PM -
79 checkmate predictor
By Merc 2.5 in forum Boat Build-Ups and RestorationsReplies: 17Last Post: 10-27-2019, 01:14 PM -
Checkmate Predictor
By 87Predictor in forum Props, Setup, and RiggingReplies: 1Last Post: 06-06-2011, 10:49 PM -
Checkmate Predictor Help
By kalugs22 in forum Props, Setup, and RiggingReplies: 1Last Post: 09-09-2009, 11:25 AM
