Results 1 to 9 of 9
    Feb 2011
    HUDSON, FLORIDA
    225 p/m temp question
    why does my temp drop as i speed up? have 2 pc plate/stats. when i slow down temp goes up. maybe 150, like clockwork, ide rather be 150 than too cold.motor been running great. any ideas why? thanks;Art
    Sep 2014
    Iowa
    What is water pressure doing during this time? Are you measuring temp in the head? Likely it is the poppet opening. Poppet opens around 12psi which is around 3k on my pmax. Prior to the poppet opening the water is held in the head which keeps it warm. I've noticed on my 200 this spring that I can only run 2-3 miles in cold water (<60f) before the temps get too cold for my liking and I have to back off or come down to idle to close the poppet and heat things back up.
  3. Likes David - WI liked this post
    Sep 2014
    Iowa
    Usually you can clearly see the water pressure surge and then oscillate or drop when the poppet fully opens
    Apr 2023
    Long island, NY
    Mine does the same thing. About 160 while going slow. Drops to around 140 at speed.
    Feb 2011
    HUDSON, FLORIDA
    pressure around 20 going slow, drops to 12 at speed. all good, my 2.4 220 burns 1/2 the fuel of the 225,, the 220 has 145 psi, the225 has 115,i run reg pump gas,220 gets 93
    Jul 2004
    Connecticut
    You are running a Promax 225 stock and your water pressure at 1500 RPM is 20lbs with an recent water pump and impeller?
    Apr 2023
    Long island, NY
    Water pressure at idol should be 1-3 psi. Poppet opens between 4 and 9.(prob closer to 9) Minimum pressure at wide open is 12psi.
  9. Likes 4Speed liked this post
    Feb 2011
    HUDSON, FLORIDA
    i could be wrong on that 20lbs.
    Jul 2004
    Connecticut
    Ahh, got it as that would point you in a much different problem solving direction. As posted above, couple lbs is what you want to see.
    I would confirm that you have 143 tstats in it. I have seen 120s in them
  1. OMC Tech: Thermostat and Temp question
    By JoshKeller in forum Technical Discussion
    Last Post: 03-03-2011, 05:26 AM
  2. BP EGT Temp question
    By Dean Dorsey in forum Technical Discussion
    Last Post: 04-17-2005, 10:42 AM
  3. Egt temp question
    By performance 900 in forum Technical Discussion
    Last Post: 07-19-2004, 03:59 PM
  4. 2.5 EFI Air Temp Sensor Question
    By G-Train in forum Technical Discussion
    Last Post: 09-03-2003, 12:12 PM
  5. temp question
    By Steven in forum Technical Discussion
    Last Post: 06-26-2003, 03:21 PM
