Results 1 to 3 of 3
    Jul 2008
    Denton, Md.
    Allison XB2003 w/2024 Yamaha 175 SHO
    I have an opportunity for a change. This beautiful 1994 Allison XB2003 Hull#33 Platinum and Black in great condition is up for grabs. Hull only has approximately 200hrs on it. 2024 Yamaha Stock 175 SHO w/35 hrs and 4 YEARS warranty remains. Boat has been completely redone from the bow to the stern. It handles absolutely great with the 175 SHO. With either the stock or coned lower unit. She ran 85 mph on a rail with the stock ECU. I am sure she is a low to mid 90's boat if flashed. She sips gas at 10mpg while cruising. This is basically a next to new boat with all the modern features. List of upgrades below. PM me with any questions you won't be disappointed, no expense spared.
    $38,000
    2024 Yamaha 175 SHO w/ 35hrs and warranty until 9/2029 (Stock-Not Flashed)
    New HydroTec Solid Motor Mounts
    Two 1.86 Ratio Lower units One Stock One Coned (No exterior hose)
    Two Props
    26P 4 blade Hill
    Spinelli 29P 3 blade
    Custom Gray Decals
    New HydroDynamics 12" Jack Plate
    New Allison Fuel Tank
    New Fuel Lines and 10 Micron external filter
    New Lockable Fuel Fill Cap Assembly
    New Auto Bilge Pump
    New Wiring
    New Custom Switch Panel
    New NoCo Three Bank Battery Charger
    New Ignition Switch
    New CL7 Yamaha Display
    New Garmin 93SV Graph
    New Hyd. Steering
    New Allison Steering Wheel
    New Yamaha Throttle Cables
    New SeaStar Pro-Pedal Foot Throttle
    New Turn Signal Style Trim Switch
    New Carbon Fiber Dash Panels (Have stock panels)
    New Seats Buckets and Bench
    New Allison Short Windshield (Have Original Tall Windshield)
    New Allison Decals
    New Custom SeaDek
    New Hardin Shifter
    New Shift Cables
    New Latches
    New Deck Lid Seals
    New Boarding Ladder/Step
    All New Hardware
    New Custom DryLock Cover
    2006 Boatmate Trailer in great condition
    New Wheels and Tires
    Vault Style Hubs
    New S.S. Ratchet Tie Down Straps
    LED Lights
ID:	542121Click image for larger version.
ID:	542122Click image for larger version.
ID:	542123Click image for larger version.
ID:	542124Click image for larger version.
ID:	541992Click image for larger version.
Name:	IMG_5428 (3) copy.jpg
ID:	541993Click image for larger version.
ID:	541994Click image for larger version.
ID:	541995Click image for larger version.
    Attached Thumbnails Attached Thumbnails IMG_5444 copy.jpg   IMG_5443 copy.jpg   IMG_5440 copy.jpg
    We only go through this circus once...so enjoy the rides!!!
  2. Likes mikesufka liked this post
    SOCAL, the land of 75* and sunny!
    Gorgeous rig. Did you try any other setbacks for the motor? I would've thought with a 4 stroke, it would like less setback. But in your pics, it seems to run right.
    GLWS
    Jul 2008
    Denton, Md.
    Quote Originally Posted by John S View Post
    GLWS
    Thanks John, no went with the 12" after contemplating between the 10" or 12". She handles great and comes out of the hole fantastic. Very little bow rise on take off and no porpoising. Absolutely love the way it rides.
  5. Likes John S liked this post
  1. 1997 Allison XB2003 yamaha 150 V-Max duo prop
    By Treeguy in forum Ebay Listings and Other Internet Listings
    Last Post: 08-16-2019, 01:17 PM
  2. Allison xb2003
    By Esox4130 in forum Hulls up to 20'
    Last Post: 02-03-2015, 02:28 PM
