Results 1 to 12 of 12
Thread: Rod bolts?
03-22-2025, 10:07 AM #1
5000 RPM
- TN
- 810
- 99
- 25
- 71
- 85
Rod bolts?
Are stock 2.5 rod bolts safe at 7000 rpm?
What about used ones?
Are WSM standard bolts the same as Promarine, Buckshot, etc.?
03-22-2025, 10:26 AM #2
Depends on who you ask. Rb8000 from promarine is the popular choice. They are priced well and strong. Never re-use a rob bolt on a performance motor imo it’s not worth the gamble. Don’t use the 90 degree ones either. I used rb8000 and torqued down in three stages ending up at 35lbs with red lock tite. Be sure to hone your rods and replace the needle bearings too if you pull the piston off
03-22-2025, 12:22 PM #3
I have re-used rod bolts forever. If they won't hold torque, you will feel it.
RockTeam Junk
03-22-2025, 12:51 PM #4
Your braver than I. For the record you cannot reuse the tty ones that some motors come with. Those are a one time
NICE PAIR liked this post
03-22-2025, 01:41 PM #5
Torque to yield bolts should never be reused. The manufacturers of the bolts tell you not to. They are designed to stretch to achieve the proper yield. If you reuse them, they are over stretched. Over stretch anything and it is weaker then designed. ProMarineusa.com is selling the RB8000 rod bolts for $3.95 each. For that price, is it worth taking a chance on windowing a block reusing a bolt?
03-22-2025, 03:49 PM #6
I have only been doing this for 40 years or so, built a hundred or more engines, and have never had a rod bolt come loose. I am not arguing that mercury doesn't recommend re-using tty bolts, just saying what has worked for me.
RockTeam Junk
03-22-2025, 06:16 PM #7
03-22-2025, 07:33 PM #8
5000 RPM
- TN
- 810
- 99
- 25
- 71
- 85
I have mixed feelings on used parts. I wouldn’t reuse the stretched bolts. I’m not racing so good used 30lb bolts should be ok. I’ve run one engine for 30 years with used bolts. Turned it 7100 rpm.
As for rod bearings, I have faith in used ones after close inspection and cleaning. I’ve torn down more than one engine with rod bearing rollers that fell out in pieces. And these were metal caged with no damage to piston.
My thought is you never really know how good a part is until it’s stressed.
03-23-2025, 12:43 AM #9
03-23-2025, 02:35 AM #10
5000 RPM
- TN
- 810
- 99
- 25
- 71
- 85
The individual roller was crumbled. It was still in place, just in pieces.
03-26-2025, 06:45 PM #11
Team Member
- Aug 2008
- iowa
- 83
- 7
- 7
Make sure you understand the difference between tty bolts and angle torque bolts. There is a difference.
pcrussell50 liked this post
03-26-2025, 09:55 PM #12
7000 RPM
- May 2009
- 2,327
- 712
- 139
- 931
- 539
- 7 Post(s)
"padded wonder"
__________
the wet:
18’ Bahner bow rider, 2.4/200
the dry:
2003 bmw ///M5
and a handful of clunkers
Mercury 3.0 liter head bolts and t- stat bolts needed
By hollywood120 in forum Parts WantedReplies: 0Last Post: 12-02-2022, 10:42 AM -
Sps rod bolts
By OCEAN OUTBOARD in forum Misc. Parts and AccessoriesReplies: 3Last Post: 03-22-2017, 06:40 PM -
insuring against stuck bolts? torquing head bolts with marine grease?
By pcrussell50 in forum Technical DiscussionReplies: 26Last Post: 07-21-2015, 10:55 AM -
Mercury Tech: 3.0l big end bolts
By R.grover in forum Technical DiscussionReplies: 1Last Post: 09-16-2010, 06:40 AM
