Results 1 to 6 of 6
    May 2009
    7 Post(s)
    Wiring two fuel tanks and ONE fuel gauge to the same switch?
    This is the setup I have.
    One switch I can flip left and right to pull from the port or starboard tank, AND when I do, the one fuel gauge in the dash, reads the tank selected.
    It’s all up and working. Only the back, of the dash is a wiring nightmare. I plan to clean it up by a lot. BUT in case I f-it up… I can no longer find the schematic I used, along with the type of switch I need (it has six lugs on the back), to replicate the work.
    Anyone point me to the right schematic/diagram? And the right switch?(DPDT?) Also where do you get quality toggle switches? Amazon has tons but I don’t know a good brand from not.
    -Peter
    "padded wonder"
    __________
    the wet:
    18’ Bahner bow rider, 2.4/200
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
    38 Post(s)
    Switch Pic
    Quote Originally Posted by pcrussell50 View Post
    -Peter
    What do you mean by "pull"? Fuel level is one thing but fuel flow gets complicated (electric valves, etc).
    Post a pic of your switch (both sides).
    - Ground ..............common
    - Positive power supply to sending units
    - Sending units power (each (+) line to toggle switch circuits)
    - Toggle switch line out to fuel gauge (+)
    May 2009
    7 Post(s)
    Quote Originally Posted by WaterZebra View Post
    the engine driven fuel pump draws fuel from whichever tank is selected. Also, the fuel gauge reads whichever tank is selcted. And it’s all wired through the switch.
    I’m searching for a diagram that tells me how to wire the switch.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    ...take photos...
    Most of the electric dual-tank valves have a switch built in to switch the gauge to the "active" tank. EFI dual-tank valves switch the supply, return, and guage together.
    Feb 2003
    peoria il
    I have that system on one of my boats but i use two toggles one for the fuel and one for the gauge.
  1. 2.4 EFI Bridgeport Fuel return for twin fuel tanks
    By sleekcraftsst in forum Technical Discussion
    Last Post: 07-30-2009, 09:24 AM
  2. Wiring in a kill switch & fuel pump
    By RikkiRocket in forum Electronics, Audio Systems, and Wiring
    Last Post: 06-14-2009, 01:04 PM
  3. Wiring in a kill switch & fuel pump
    By RikkiRocket in forum Technical Discussion
    Last Post: 06-12-2009, 10:49 AM
  4. Vintage Airguide fuel level gauge wiring
    By mr_velocity in forum Technical Discussion
    Last Post: 01-13-2008, 07:34 PM
