Results 1 to 15 of 15
    Aug 2002
    waterloo IN
    Help with fastest prop style for 95 Eliminator Daytona
    So far, I have ben to 107 mph with a 15x32 Performance propellor drag4. It has a 300x with 14 inches of setback. I have thought about getting a 34-pitch built for it. I am Shure someone knows a whole lot more about what blade profile would be the best for top speed than I do. I would like to hit 110 that seems like a nice round number. Thanks for your input.
    Long Island NY
    14.5x34 or 15x34 Lab reference Cleaver three blade unfortunately they don’t make them anymore. That’s the prop you need
    I would love to see how a Mercury CNC prop would run on a boat like that... not sure what shaft size options they offer.
    Four blade overhub DeWald is what I would try. They get on plane well with a light weight hull and work in conjunction with 300X torque capabilities. We have run them for years on our STVs. The 5 blade cnc is an incredible wheel but takes a torque monster to turn it in comparison. The four blade also provides a better slip factor and is easier on the gearcase Vs. a 3 blade.
  5. Thanks David - WI thanked for this post
    Feb 2010
    wisconsin
    I would turn the 32 into a 33.5 or so... The CNC 5 blade you won't be able to turn along with it being 5 blades. If you wanted to try a new prop i would try the signature 4 blade 15 degree rake cleaver in 15". Have myself or someone work it and they go all the way up to 36 pitch.
  7. Likes OnPad liked this post
    Aug 2002
    waterloo IN
    I talked to DeWald He said he would get back with me if he had something to try but cnc props are not cheap. It seems like that they mostly work on bigger boats. There is only one place by me with enough room to let it rip long enough to get the top rpm it is kind of dumb to waste all that money chasing 3 mph. I like the way the drag4 runs on this boat and know I am doing pretty good now from what I have read here. But it would be nice to have 110mph bragging rights, it might do it now on a 50-degree day.
    Aug 2002
    waterloo IN
    Do those Signature props run without being worked? And what about that Bullet cut performer from Hill?
    Feb 2010
    wisconsin
    Quote Originally Posted by Wild Bill View Post
    I would say no on the bullet cut from Hill.... The signature cleavers work "ok" without being worked.. I would suggest running it first and seeing where your at then send it out... Normally from stock to worked people gain about 3-5mph sometimes a touch more.
  11. Likes OnPad liked this post
    So, really this is all bull****? You ask about a faster prop and then say going faster isn't worthwhile?
  13. Likes donmac, bigboy liked this post
    Aug 2002
    waterloo IN
    David it is worthwhile, I am just looking for the best way to go. And thanks for your input you have been helpful.
    Lake Coochiching, Ontario
    What about an ET? That was the prop of choice in a Hotboat article about the 21 Cougar a long time ago. Similar boat.
  16. Likes XstreamVking liked this post
    Nov 2021
    Northwest
    A 4 blade Signature cleaver that Hill labbed is the fastest prop I've tried on a ltv. I also run a Signature eagle 4 blade on a Bullet, it runs faster than most props, but the blades are a bit heavy. I've found a mazco re3 to be faster on that boat, but the blades are scary thin.
  18. #13
    Aug 2002
    waterloo IN
    My favorite prop was a Hoss Hyperdrive 15x30, not the fastest though, but after throwing a blade on two of them I went in a different direction. I tried a friends RE3 on my Vector once and didn't care for it, it didn't seem to fly the boat. But he had a rapid craft. I thought ETs were blade throwers too. I always thought cleavers were stern lifters and never had the opportunity to try one. I guess I will poke around for a used one. Or maybe I will get a labbed new one too, I have been told I can't take it with me.
    It seems like Randy Corson, Wild Man favored drag 4's for some reason. I think I will be making some calls this week.
  19. #14
    Aug 2002
    waterloo IN
    I will try to find that Hot Boat article, I have a stack of them from a friend that passed.
  20. #15
    This guy has an "index" for HotBoat... you might be able to figure out which issue: https://issuu.com/brettbayne/docs/hb-index
    Hard to read, but the info is there:
    Attachment 541113
  1. Eliminator Daytona 21 Prop
    By Lhliberator in forum Props, Setup, and Rigging
    Last Post: 02-11-2016, 12:08 PM
  2. Eliminator 21 daytona 225 pro max prop choice.
    By EliminatorJEFF in forum Props, Setup, and Rigging
    Last Post: 12-08-2014, 03:03 AM
  3. 21 Eliminator Daytona prop
    By ActivatedSludge in forum Props, Setup, and Rigging
    Last Post: 08-02-2014, 05:08 PM
  4. Prop? 300XS - 21 Daytona Eliminator.
    By FLTPLAN in forum Props, Setup, and Rigging
    Last Post: 05-27-2010, 03:28 PM
  5. Prop Size , Eliminator Daytona 21'
    By MirageBoy69 in forum Technical Discussion
    Last Post: 10-01-2008, 07:53 AM
