Results 1 to 15 of 15
02-24-2025, 09:44 AM #1
Team Member
- Apr 2014
- nj
- 528
- 17
- 126
Is it possible to use 250 efi downdraft intake on older 250efi ?
Is it possible to install late model 250 efi downdraft intake on older twin ecu 250 efi ? TO BE CLEAR not referring to 300 x , rather 250 efi downdraft . I know it will bolt right on , question what injector do I use ?
Thanks
02-24-2025, 11:43 AM #2
Good question see how the push rods line up on both
Im going to say not without modification because the blocks are cast differently in some areas
02-24-2025, 11:48 AM #3
Team Member
- Apr 2014
- nj
- 528
- 17
- 126
Thanks ! I installed 300x intakes on older 3 litre with minimal fuss so I know its a direct bolt on other than bell crank and rods which I have piles of , question is use what injector to work with older twin ECU
02-24-2025, 11:56 AM #4
Thats a good question hopefully someone else will answer because I am not sure if the older white tips will work with the newer motorola ecu
02-24-2025, 11:59 AM #5
Team Member
- Apr 2014
- nj
- 528
- 17
- 126
Exactly !! Thanks for reply
02-24-2025, 12:01 PM #6
02-24-2025, 01:39 PM #7
Team Member
- Apr 2014
- nj
- 528
- 17
- 126
Again I used a 300x intake with on older 3 250 . I simply need to know what injector to use
02-24-2025, 01:43 PM #8
Team Member
- Apr 2014
- nj
- 528
- 17
- 126
All above are my Shaun Torrente STR engines that genius built me that lasted . He built the long blocks ONLY , 10 min on test stand before they started coming apart , paid him big money and he just said oh well . Keep hoping for Karma like a fiery boat wreck !
NICE PAIR liked this post
02-24-2025, 01:43 PM #9
Larry, when you say intake.
Do you mean just the plenum than throttle body or the reed adapter plate that mounts the injectors internally as well ?
If externally, the white tip 14 ohm injectors that came in all early models.
If internally, you will need a 12-14 ohm Deca (short) type injector.
02-24-2025, 03:48 PM #10
Team Member
- Apr 2014
- nj
- 528
- 17
- 126
Im not referring to the 300x style with injector in reed plate . Im using the internal OEM 2003 250 efi induction on older twin ecu junk . What injector came on 2003 250 efi ? Thanks
LarryLast edited by LOSTINJ; 02-24-2025 at 04:10 PM.
02-24-2025, 09:47 PM #11
02-25-2025, 12:33 AM #12
Team Member
- Apr 2014
- nj
- 528
- 17
- 126
and the Deca 12-14 ohm is 100 % capable with this old twin ecu hunk of **** ?
Thanks big guy
02-25-2025, 09:37 AM #13
Yes .. the early model (Denso) twin pack motors fired two injectors at one time. All it could handle was a saturated (12-14 ohm) injector. Back then they used a white tip Keihin (Bosche type) injector that blew aprox. 500 cc / min.
The later Motorola had six injector drivers that could be configured to run either a pink tip (2 ohm) Keihin 300x or a (12-14 ohm) Deca 225-250 injector.
Not knowing the port timing and compression of your motors, your best bet is to have your injectors flowed at different pressure levels. (43.5 to 55) 5 psi one way or the other might be the difference between 490, 500 and 510 cc/min. Which would cover the 250 to 300+ HP range pretty well .
big tom liked this post
02-26-2025, 12:12 PM #14
Well mr 3 liter has spoken
03-04-2025, 08:16 PM #15
Member
- Aug 2008
- iowa
- 53
I think I bought a down draft complete fuel system from you. I sure didn’t like the sound of your engine only lasted 10 minutes. But I would really appreciate all those pictures like the ones above. I will take all you can send me. I bought a basket case so I didn’t take it apart. The guy I bought it from did a very good job of bagging and labeling all the parts. But a bunch of pictures could really help.
SVS for 300x or late model 3.0 with a downdraft intake
By opsdave in forum Misc. Parts and AccessoriesReplies: 2Last Post: 12-21-2015, 09:24 PM -
reg 250efi with laser style intake vs 2005 250efi with the single tbody up top???
By syclone01 in forum Technical DiscussionReplies: 14Last Post: 09-01-2013, 03:36 PM -
3.0L Mercury 4 shutter intake or single downdraft??
By tony1204au in forum Technical DiscussionReplies: 13Last Post: 07-24-2012, 09:57 AM
