Results 1 to 4 of 4
    Feb 2022
    Mercury 450r seems to not be making full power. Help
    I had a used 450r put in a small light boat. 21' 1200 pound hull. Once out on the water we tried a 28p chopper but can't get full rpms. Tried a 23p on a rough day and got 6200 but maybe could have gotten 6400 if it was better conditions. A 450 should easily turn both of those props on a lite boat.
    Does anyone have experience with these motors? I know the fuel line needs a 1/2" i.d. what about the fuel water separator? What size do the fittings need to be? SHould I check spark plugs, fuel filters, etc? There are no codes
    Aug 2015
    Southeast
    Quote Originally Posted by axm0z5h View Post
    Throttle position sensor would be a good start. Dealer needs to use their merc software to check it. When I got a new 250 v8 on a bass boat mine was way off. Engine ran perfectly just didn't make full power.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship" Sold
    Blazer 650 Pro Tour
    30ft Cobra with Triple 280's
    Feb 2022
    I think we may have found the issue. Apparently the 450 when ran in saltwater is known to have corroded tensioner pulleys for the supercharger. If that happens the belt will slip and it won't build boost. Trying to verify this is the issue now
    Feb 2025
    SC
    Got a pic of the Bullet you have the 450R Mounted on ?
    Kenny Hollingsworth
    2022 Blazer 675 Ultimate Bay
    Merc 300 Pro XS
  1. Replies: 0
    Last Post: 10-30-2021, 09:35 AM
  2. Mercury Tech: 115HP Mercury EFI making one beep at full throttle
    By RIB1 in forum Technical Discussion
    Last Post: 06-10-2021, 09:07 PM
  3. Power making 2.4 s
    By evinrudejohnson in forum Technical Discussion
    Last Post: 11-13-2015, 07:20 AM
  4. 2.5 liter 240 sportjet not making full power.
    By blen in forum Technical Discussion
    Last Post: 09-09-2014, 07:24 AM
  5. Let's Discuss 2.5 Blocks and Making Power
    By Liqui-Fly in forum Technical Discussion
    Last Post: 09-06-2002, 06:48 PM
