Results 1 to 15 of 16
    Apr 2023
    Long island, NY
    Lightweight cowl pan repair.
    I have been looking for a lightweight cowl for a while now. I finally found one. A very rare Formula 1. It's really cool but it needs some work. The cowl itself has some minor cracks and has been painted. is peeling. It needs to be repainted. The pan is1the real problem. It has a bunch of cracks and a couple poorly done old repairs. It's useable the way it is. But I want to fix it. What would be the best way to fix the cracks? I tried structural plastic epoxy once on a broken plow light. It seemed to work. But it didn't look great. Plus, I didn't have it long, so I don't know if it lasted. My other Idea is to duplicate it out of fiberglass. I can use the original one to make a mold. Then 3 or 4 layers of matting should be strong enough. The hard part is sanding it smooth. I did something similar with the dashboard on my Glastron. Used the old broken dash as a mold. Modified it to fit more gauges. I came out great.
ID:	539880 Click image for larger version.
ID:	539882 Click image for larger version.
ID:	539883 Click image for larger version.
ID:	539886 Click image for larger version.
    Jun 2018
    Floating around
    I used stainless plastic welding staples. Mine was a lot worse than that and they have held up great.
    45 Post(s)
    Hot Iron Repair
    Quote Originally Posted by skialot2 View Post
    I don't remember what Merc used for plastic material but these buckets and pans started out as beads and were roto molded. The bucket was a split half assembly then bonded at the centerline lap seam. Since you plan on splashing the pan anyway, try a hot iron (heated by torch) to smear and fuse the crack lines. Repairing any cracks at the tie down locations never hold up. Before you splash the pan use molding clay to form any additional "ribs" to stiffen the pan up were cracked. If you are really clever, your new pan could be split in two pieces fwd/aft along the centerline so pan can be removed without pulling the powerhead (center tin plate). The center tin plates were cad plated by Merc. I would NOT powder coat the plate because it might affect the exhaust and water gasket sandwich (bond layers). Merc never intended these bucket and pans to be repaired. They were usually pitched in the trash and replaced.
  4. Likes skialot2 liked this post
    Jun 2018
    Floating around
    Replace the base plate with new stainless. Buckshot marine sells them
  6. Likes WaterZebra, skialot2, 99fxst99 liked this post
    Miami,Fl
    I think someone on here made stainless base plates.
    45 Post(s)
    Drilling?
    Quote Originally Posted by delawarerick View Post
    Whether the plate is OEM or stainless, they are a bitch to drill on.
    Apr 2023
    Long island, NY
    Yes, Buckshot sells stainless base plates. They also sell the coil mounting bracket to make the coils fit under the cowl.
    Jun 2018
    Floating around
    Jones marine design. That’s who I got mine from. Good plate, good price
  11. Likes 99fxst99 liked this post
    Mar 2004
    Brooklyn Park, MN
    if you are still looking for filler that works well with cowl plastic we have used K-Bond to fix cowls and pans.
    https://koverbond.com/en/usa/
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  13. Thanks skialot2 thanked for this post
    Apr 2023
    Long island, NY
    The formula 2 decal is just a little rectangle over the original decal on this cowl. I am going to have to replace the decals when I repaint it. So I decided to peel it off. The Original is Formula 1. But the only replacement decals I can find say Formula 2.4 liter. Maybe I will have them customized to say Formula 2.5 Liter. Because I will be using it on a 2.5
    Jun 2009
    Bristol, Connecticut
    I like the idea of making a fiberglass mold off it, lotta work but it can be done...
    If you put PVA on it does it bead up?
  16. Thanks skialot2 thanked for this post
    Jun 2018
    Floating around
    I used plio grip flexible parts repair with fiberglass screen after the staples trick. I bought the screen at Home Depot. As in window replacement screen
  18. Thanks skialot2 thanked for this post
  19. #13
    Feb 2011
    HUDSON, FLORIDA
    i do a lot of glass work, made glass bumpers for my nova drag car, using oem chrome bumper as the mold. on your
    pan, i would cut some glass cloth[carefully] to lay between the existing ribs[2-3 layers, then 1 layer over the ribs and all,make a template of pan,sharpie to mark the cloth. make cardboard templates for shapes between ribs. you will end with a nice close weave finish, mininum finish work.............your a craftsmam ski, nice work on that dash
  20. Thanks skialot2 thanked for this post
  21. #14
    longisland
    I make fiberglass pans for that cowl
  22. Likes Frank Molé, 108, delawarerick liked this post
  23. #15
    Apr 2023
    Long island, NY
    Quote Originally Posted by RONNIE View Post
    Cool. How much do you charge for one? I am on long island too, so no shipping needed.
  1. could it be lightweight cowl???
    By BoatR in forum Technical Discussion
    Last Post: 08-12-2009, 04:45 PM
