Results 1 to 15 of 26
01-17-2025, 06:11 PM #1
Selling the last of my Performance stuff
Getting rid of the last of my stuff from my boating years
Factory 7 Petal cross drilled intake. $150 (sold)
260 ECU braket $85 (Sold)
New Vertex Mercury STD 3.5 bore pistons. 2 Port and 3 Star. $60ea (Sold)
1 WSM .015 over Port Mercury 2.5 piston same as above
2 small bearing hi perf BP EFI front half. $100ea (1 sold)
1 early vertical shaft Air horn $75
1 horizontal shaft bored Air Horn $75
1 small bearing 2.4 7petal front half. $40
1 pre oiler 7 ring $200
Eight Switch boxes (sold)
Hgh Perf 245/260 exhaust chest divider. $200
(2) 15227-c1 18cc O-ring heads small deck (teflon o-ring and silicone for water jacket) High 200's to low 300's depending on bore. $90
(2) 18488-c2 cleaned up unknown cc $75
(2) 18488-c4 heads 1 with light damage $50
(2) 18488-c4 heads 2 with damage $30
Chris
512-567-3299
rjdubiel liked this post
01-21-2025, 01:35 PM #2
Parts added. Piston Prices lowered.
Correct phone number added
01-21-2025, 04:29 PM #3
Anyone looking for a clean 2.4 BP front hit Chris up!
And FYI, if you are looking for a 2.5 small bearing crankcase injection front, Jeff Dunn is still willing to machine a 2.4 BP EFI Front Half to work in a 2.5 small bearing application. Grab one of these fronts from Chris, ship to Jeff Dunn, and now you have a small bearing 2.5 crankcase injection front half!Last edited by rjdubiel; 01-22-2025 at 10:10 AM.
1973 Viper - sold
1978 Viking - sold
1995 XB02
01-22-2025, 02:23 PM #4
Crankshafts added
01-22-2025, 03:27 PM #5
2.5 Laser EFI complete with intake and 150hp ecu. Bolt it to your 2.4 lake motor. The fuel curve works great....$250
01-22-2025, 03:29 PM #6
40amp ignition system, complete with flywheel. $200
01-23-2025, 04:11 PM #7
5000 RPM
- Sep 2021
- Buffalo, NY
- 118
- 450
- 24
01-23-2025, 08:32 PM #8
I’m on a job and won’t be back till Sat. Let me get home and verify it’s all there.
Be patient with me.
ctobias1984 liked this post
01-23-2025, 08:51 PM #9
5000 RPM
- Mar 2024
- Michigan
- 139
- 31
- 35
- 278
- 164
I'll give you a call sat afternoon. I'll take the vertex pistons.
01-23-2025, 09:01 PM #10
108 liked this post
01-25-2025, 01:04 PM #11
The System is complete. Stator, trigger, switch boxes, coils and bracket, voltage regulators, Flywheel and cover, wiring harness.
Its missing some of the mounting bolts but for the most part is complete..
It can be made to work on your XR4 and is a straight bolt up except for the coils and voltage regulators. You could use your coils and make a bracket for the regulators.
If you run alot of electronics on your boat, this will help keep the batt charged.
Your call
01-25-2025, 02:36 PM #12
5000 RPM
- Sep 2021
- Buffalo, NY
- 118
- 450
- 24
01-25-2025, 02:46 PM #13
Key won’t do that to a stator Disconnect the kill wire from each pack. See if things change.
01-25-2025, 03:00 PM #14
5000 RPM
- Sep 2021
- Buffalo, NY
- 118
- 450
- 24
01-25-2025, 03:09 PM #15
Unless you already have a 40amp system, it’ll take some work to change.
Selling......My 125 BP stuff.....
By Dave S in forum Outboard EnginesReplies: 2Last Post: 12-06-2023, 04:15 PM -
Selling XS Stuff
By TroyWoodF1 in forum Outboard and Racing HistoryReplies: 0Last Post: 07-08-2008, 02:36 AM -
Selling some race stuff
By Guy Hanson in forum Outboard and Racing HistoryReplies: 5Last Post: 06-18-2008, 10:57 PM
