Results 1 to 4 of 4
    Oct 2017
    Jackson Ga
    HELP!!! Need Tilt tube in a bad way!
    I’m in desperate need of a Mercury 2.5 tilt tube. Purchased motor for my
    boat.. and it all ready to go ride except the tilt tube. It has a steering cable stuck in it and I’ve done everything possible to get
    it out. Please text me if you have one laying around willing to ship. 678-544-5101
    Apr 2023
    Long island, NY
    Part number should be 826125A1. There are several available on eBay. The motor it came off does not matter. Most motors take the same tube. Shop by part number. Make sure you get a stainless tube. This is just one example
    2005 Mercury 90 HP 4 Stroke Outboard Clamp Bracket Bolt Tilt Tube 826125A1 OEM | eBay
  3. Thanks JSons thanked for this post
    Oct 2017
    Jackson Ga
    Found one local guys. Thanks for the help.
    Pekin, IL
    Just changed one on a 280. Took a piece of 3/4 black pipe and turned it down to same dimension as tube. Was then able to push out old tube and then push in new tube without having to mess with lining things up. Took less than a minute to change tube once "tool" was made.
    Rock
    Team Junk
  6. Likes rjdubiel, delawarerick liked this post
  1. Tilt Tube and Swivel Tube Bushings?
    By 2.5-21 in forum Technical Discussion
    Last Post: 09-02-2016, 08:17 PM
  2. Tilt tube came out. Help!
    By HarleyG8r in forum Technical Discussion
    Last Post: 07-09-2010, 10:39 PM
  3. Tilt tube
    By OrangeCrush in forum Technical Discussion
    Last Post: 11-20-2005, 06:35 AM
