Results 1 to 5 of 5
    Aug 2016
    SACRAMENTO
    Trailering Recommendations
    Hey gang, looking for recommendations on trailering with these 200Hp DFI's ...full download position = possible damage although there is clearance. Do you recommend using aluminum milled blocks that slide over trim ram posts? The motors are mounted on Armstrong aluminum motor/swim platform
    Attached Thumbnails Attached Thumbnails Screenshot_20250110_073639_Photos.jpg
    I live in Prineville Oregon which is in the central part of the state
    I would want to find a way to balance them over the mount so the weight is balanced not be just hung off of the back which allows them to bounce around. Bouncing motors are not kind to a hull.
    Carter Powell
    Apr 2023
    Long island, NY
    If I am going to trailer for any real distance I tilt the motor up, then put a 2 x 4 above the trim rams. Then trim down and pinch the 2 x 4. Keeps it tilted up some for more clearance. but takes the pressure off the trim system. Just like your aluminum blocks would do. You can than strap it down if you are worried about the motor bouncing.
  4. Likes XstreamVking, Greg G liked this post
    ...just trim them up if only a few miles to the ramp. trim buttons on the sides of the motors. no biggy...
  6. Likes OnPad liked this post
    May 2001
    Maine
    If towing any distance and equipped with hydraulic steering, I would add a set of Steer-Stops by T&H Marine to keep the motor straight. Just remember to take them off before launching.
  1. Trailering an STV-- Motor down
    By keane in forum General Boating Discussion
    Last Post: 05-19-2012, 07:40 AM
  2. New Here looking for a little help if possible with trailering a new boat
    By cbellamore in forum General Boating Discussion
    Last Post: 07-23-2009, 04:17 PM
  3. Trailering question
    By cocacola in forum General Boating Discussion
    Last Post: 03-24-2007, 10:32 PM
  4. trailering
    By dlgorie@yahoo.com in forum Technical Discussion
    Last Post: 12-06-2006, 02:02 AM
  5. Trailering a Hydrostream
    By LSaupe in forum General Boating Discussion
    Last Post: 07-11-2006, 07:18 PM
