Results 1 to 12 of 12
Thread: 1.25 Hub
    May 2001
    Maine
    1.25 Hub
    Anyone tried one of these hubs?
    The snubbers look like they would last much longer without sliding to the side
    Doc1.pdf
    Aug 2015
    Southeast
    Interesting. Haven't seen that style yet. I've used the SSR style and they do shift smoother, but can take a press or at least a bottle jack to get the hub out.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship" Sold
    Blazer 650 Pro Tour
    30ft Cobra with Triple 280's
    May 2001
    Maine
    Saw them on the Buckshot Racing #77 site
    Dec 2017
    Okeechobee FL
    theres another design that has 2 nuts instead of the washers to keep everything tight.
    Aug 2015
    Southeast
    Are these Merc parts or somebody else?
    Blazer 650 Pro Tour
    Jan 2020
    Pittsburg, Ca
    Mercury has revised all of the high performance 1.25" hub kits to come with the double nut and a single washer rather than the stack of 3 washers.
    Aug 2015
    Southeast
    Interesting. Tks for the update.
    Blazer 650 Pro Tour
    May 2001
    Maine
    I wonder if Mercury updated the rubber snubber design with the 2 nut system? If the new design included snubbers that filled the entire machined groove as opposed to just the current 1/2" wide black strips that would be awesome.
    May 2001
    Maine
    Found the 2 nut and single washer system on the Mercury Racing site. #8M0179579. Says it can be used with the 8M0183487 & 8M0217764 hub kits when mounting any outboard CNC cleaver to 1.25 or 1.50" prop shafts
    Aug 2015
    Southeast
    Quote Originally Posted by 4Speed View Post
    When I had 300R's with 5 blade clevers, they were bad about loosening. I was going way beyond torque spec and they would still loosen consistently. Never any issue on any of my 2.5 merc. Maybe others had the same problem.
    Blazer 650 Pro Tour
    Jan 2020
    Pittsburg, Ca
    Quote Originally Posted by DangerNewb View Post
    I have not had any loosening issues with 19 spline hub kits. 15 spline yes....
    Las double nut 19 spline hub kit I got in a couple days ago still had the same size rubber strips on it.
  12. #12
    Aug 2013
    Oshkosh, WI
    8M0183487 is the 1.25" hub kit with the newer double nut system. The machined taper was updated for better fitment but no other changes. 8M0217764 is the 500R hub kit. 8M0179579 is the standalone double nut and washer kit that's designed to be used on cleavers, or replacing old hardware. The Mercury SSR hub kit, which is the half rubber 1.25" kit, did not get the double nut update.
    2000 Triad Mod VP 280 ROS
