Results 1 to 9 of 9
    Jun 2018
    Floating around
    40 amp flywheels red vs black weights
    I have heard mention many times there is a weight savings between the two but never saw a definitive answer. I have a black 40amp flywheel part number 271-817632-C1 which weighs 12lb 10oz and a red 40amp flywheel
    part number 4398839 which weighs 10lbs 12oz
ID:	538617 Click image for larger version.
  2. Likes VkingMike liked this post
    Jan 2020
    Pittsburg, Ca
    They made different variations of the black one too. Some have like twice as many vents in the top as the other. Not sure which came on what.
  4. Likes LakeFever liked this post
  5. #3
    Aug 2021
    Osteen/Deltona, FL
    I did this swap on my current fishing motor for the 2lb weight savings.
    Good info for people searching the web like I did.
    83 Vking 150 Mariner 2.5L
  6. Likes LakeFever liked this post
  7. #4
    Jun 2018
    Floating around
    I spun my black one up to 7200 last time out. Thats getting scary for a cast piece weight savings aside I wouldn't run a cast flywheel or balancer on any race car motor I built at that RPM either. The flexplate aspect of the red one is a substantial step up in safety at higher RPM. The 2lbs is nice too
    Jun 2018
    Floating around
    I have 5 or 6 black ones now I just grabbed one that was handy for this test hence the part numbers so I dont offer any conflicting info. I've been bit by that before thinking I had bought a unicorn part when it turned out to be a doppelganger pos lol
    Aug 2021
    Osteen/Deltona, FL
    That's why my new motor will be running a 16amp Mercury racing aluminum I got from 25two.stroke
  10. Likes 25two.stroke, LakeFever liked this post
  11. #7
    Black Creek WI
    If anyone is looking,I have a red 40amper for sale just pm me, also have three 16amp left handed and one right hand light weight fly wheels for sale, all with no cracked or missing magnets.
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
  12. #8
    Jun 2018
    Floating around
    Quote Originally Posted by VkingMike View Post
    same. I’m building a 260 ported FF laser with a 7 petal front and a 16amp lightweight set up. My current motor will become the back up when I get this built. I’m hoping to have the powerhead built by spring but we all know how these plans and schedules like to be at odds with one another lol
    what are you going to build?
  13. Likes Baker343 liked this post
  14. #9
    Aug 2021
    Osteen/Deltona, FL
    It's already built and just sitting on the workbench. It's a standard 200 with some port work and cut heads. Still using carbs.
    That my plan too, just need to swap these powerheads eventually, keep my current as a good running backup.
  15. Likes LakeFever liked this post
  1. Outboard weights
    By PRE-Z06 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-25-2018, 06:13 PM
  2. Weights of motors
    By graemers in forum Props, Setup, and Rigging
    Last Post: 11-04-2006, 05:21 PM
  3. OMC V4 motor weights
    By NNT in forum Technical Discussion
    Last Post: 03-07-2006, 08:39 PM
  4. Crankshafts - 3 different weights
    By W. Tripp in forum Technical Discussion
    Last Post: 02-12-2006, 03:29 PM
  5. Powerhead weights
    By JTS Racing in forum Technical Discussion
    Last Post: 10-20-2001, 10:49 PM
