Results 1 to 5 of 5
    Sep 2024
    Prop help please
    I have a 21 ft cobia center console that I have just redone the floor and transom and I'm just getting it on the water , with that said I have a 1990 Johnson 125 25" shaft and when on plane if I give it all the throttle , it will hit 6700 - 6800 rpm quickly .
    I feel this is too much and the prop is a 13 3/8 X 17. Is this close to the right prop ? There is evidence of the rubber hub slipping some but I don't want to pay to have it re worked just to figure out it's the wrong one anyways .
    Lake Coochiching, Ontario
    How fast does the boat go? Is 6700 a transient rpm while planing or the rpm at top speed?
    Sep 2024
    According to gps and fish finder around 34-35 mph if I remember correctly .
    6700 is all the rpm at top speed . The boat itself comes up on plane easy and quick , just worried about the excessive rpm .
    I live in Prineville Oregon which is in the central part of the state
    If the hub is slipping it is a real problem. From what you have posted I would really think about going to a 19" pitch prop. That should lower your RPMs by about 200 RPM. A four blade prop will also give you better control in rough water and less propeller slip.
    Best wishes, Carter Powell
    Feb 2011
    HUDSON, FLORIDA
    you can check your hub, put a 2x4 in so the prop wont turn, engine at idle, shift in to foward. engine should stall immediately. have someone look at a safe distance. worked for me.
  1. Replies: 1
    Last Post: 07-09-2023, 05:50 PM
  2. F1 / F2 Racing Items for Sale!! Dewald props, Performance Prop, Prop test wheel...
    By Spectre Powerboats in forum Misc. Parts and Accessories
    Last Post: 02-20-2018, 03:01 PM
  3. Replies: 1
    Last Post: 02-03-2018, 02:08 PM
  4. OMC Tech: Help! 225 carbed Johnson melting prop hubs / high exaust temps through prop hub
    By Tunnelvision1995 in forum Technical Discussion
    Last Post: 09-12-2017, 08:03 PM
