![Thanks](https://www.screamandfly.com/dbtech/thanks/images/thanks.png)
Results 1 to 7 of 7
12-07-2024, 05:57 PM #1
Member
- Aug 2014
- Houston
- 35
1996 Johnson 225 Venom bottom starboard carb leaking badly out big top hole?
About a year ago my trailer axle gave out on the way home. Well, I finally blasted and redid the whole trailer new axles and everything else, so it has been a while sense I ran it. I only run ethanol free because I am tired of all the problems that come with the E gas. Anyway, when I started it up today gas was pouring out of the big hole at the top left of the bottom starboard carb. It might have been leaking out the little copper hole at the bottom center in the first picture, but it was hard to tell from the amount of gas coming from the top hole. is this just a stuck float or a bigger problem? Hopefully not a bigger problem because I just blew the budget on the trailer.
12-07-2024, 06:04 PM #2
Stuck float.
pc of cake to fix.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
12-07-2024, 06:17 PM #3
Member
- Aug 2014
- Houston
- 35
Perfect, I ordered A Carb kit for it figured if I had to take it off, I would rebuild it. Thanks for the quick response.
12-08-2024, 10:02 AM #4
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,601
- 19
- 256
- 206
- 484
- 5 Post(s)
Get rid of those aftermarket carb kits and install OEM
108 liked this post
12-08-2024, 10:18 AM #5
I had one do that on one of the twins on my Convincor.
Appeared to be a tiny sliver of rubber off the inside of a fuel line, from a connection somewhere!
Could barely see it, wedged between needle and seat!I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
12-09-2024, 12:46 PM #6
6000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,437
- 61
- 437
- 3405
- 4661
Instigator liked this post
12-09-2024, 01:53 PM #7
parting out 1996 johnson 200 venom
By anthony714 in forum Outboard EnginesReplies: 1Last Post: 04-27-2021, 12:49 AM -
1996 johnson venom 225 started knocking
By Jewn.beef in forum Technical DiscussionReplies: 1Last Post: 08-05-2013, 09:29 AM -
OMC Tech: 1996 Johnson V4 90hp - starboard side overheating?
By fishnsane in forum Technical DiscussionReplies: 12Last Post: 05-16-2012, 07:14 AM -
1996 Johnson 225 Venom compression question
By stratosman201 in forum Technical DiscussionReplies: 3Last Post: 05-27-2008, 05:51 PM -
Lightning gearcase on 1996 Johnson 200 venom
By evernole in forum Technical DiscussionReplies: 7Last Post: 06-16-2006, 06:13 AM
