Results 1 to 7 of 7
    May 2021
    Malta
    Wanted Merc 2.5liter intake
    Currently doing a 2.5 225hp Promax with 260hp port spec sleeves build and looking for an intake something along the lines of the mad efi intake but would consider even going crank case injected depending what i find what do y'all have and what do you recommend.
    RhysMLT
    Mar 2004
    Brooklyn Park, MN
    good luck on your search. I would try to find a 260 small bearing front but they are hard to find. Mad EFI are cool but also hard to find and you will have to test and find a fuel curve that will work well with it.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jun 2018
    Floating around
    Why not run a laser?
  4. Likes pkstv liked this post
    Mar 2004
    Brooklyn Park, MN
    I do want to try a slide intake on the laser system on my promax. I have not been able to make a stock laser behave like a horn motor.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jun 2018
    Floating around
    what do you mean by behave?
    Mar 2004
    Brooklyn Park, MN
    throttle response. Just seems the laser is sluggish VS crankcase injection. I do see some very strong laser motors on FB so it must be able to be done, I just have not spent that time on running my 225 that I keep as a backup to my 280.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jun 2018
    Floating around
    I can second that. The throttle response is quite lazy with my laser too. It’s runs out hard up top though so it’s not terrible it’s just a little boring. The lower unit is probably thankful for it. I have seen threads with guys who installed larger butterflies in the laser intake and had good things to say.
  9. Likes rjdubiel liked this post
  1. 3L Merc Mad Efi Intake Wanted
    By Amatuer in forum Parts Wanted
    Last Post: 06-15-2024, 04:26 PM
