Results 1 to 15 of 15
Thread: WANTED Chrysler racing outboard
11-24-2024, 06:56 PM #1Member
- May 2014
- Australia
- 97
Wanted Chrysler racing outboard ( Stacker)
Complete outboard or parts
108, ctobias1984 liked this post
11-25-2024, 09:00 AM #2
Not sure if this is still available but I saw it a while back on FB Marketplace. https://www.facebook.com/marketplace...60533665537359
11-27-2024, 02:38 PM #3Member
- Mar 2023
- Elephant Butte, NM
- 47
- 31
Saw this ad on Chrysler Marine group on F/B:
"Hey to all Chrysler fans, Happy Thanksgiving !I have two NOS, racing lower units, Chryslers version of the SpeedMaster, along with one exhaust tower, mid section, and two props.
In addition an NOS racing lower unit housing, empty, and one of the chrome stack extensions.
Anyone interested ? E-MAIL boatracer966@gmail.com for photo's.
Thanks and Happy Holiday's"
11-27-2024, 02:46 PM #4Member
- May 2014
- Australia
- 97
send some photo,s and details please and your location
mirf90@live.com.auLast edited by gem56; 11-27-2024 at 03:36 PM.
11-28-2024, 08:00 AM #5Member
- Mar 2023
- 47
- 31
12-10-2024, 07:24 AM #6
I have a 150 stacker I would sell. It has the speedmaster lower but is missing the nose cone. Otherwise, complete. Not running but turns over by hand.
12-10-2024, 03:01 PM #7Member
- May 2014
- Australia
- 97
12-10-2024, 08:50 PM #8
I'm in Evansville Indiana. I'll dig it out and take some pics.
12-13-2024, 06:56 PM #9
12-17-2024, 10:37 AM #105000 RPM
- Sep 2021
- Buffalo, NY
- 110
- 444
- 24
Thats really cool, whats the hp on something like that? Rpms?
12-22-2024, 09:16 PM #11
I have never ran mine. It is rated at 150 hp. Not sure on redline either.
12-25-2024, 10:48 AM #12Screaming And Flying!
- Feb 2015
- Ontario
- 8,108
- 205
- 323
- 1930
- 2011
Square head, top flat surface of the block and on the flat side surface of the head you'll find a 3 digit stamped code.
On the block behind the coil #1 you'll find a year casting.
Blocks and assemblies can get switched around over the years, more behind the stacks too and not just a bolt on if blocks swapped.
150 started out 96ci 3.3125"x2.8 then also had a 100c.i. 3.375"x2 8"
Should be a studded head , oring deck if original 96ci but the square head was '75 release and likely a big bore.
Correct tested, not oiled up, carbs wide open PSI should be 185-195. If the grouping isn't real tight, pull the transfer covers and tension check the rings through the transfer ports with in out pressure, they must follow. Top rings breaking can show a decent psi if recent.
It'll have true high ring pressure backed pistons .
Jets should be 106 range but that can be changed, carbs will have casting date on the portside.Last edited by FMP; 12-25-2024 at 03:59 PM.
12-26-2024, 11:51 PM #13
So the square flat cylinder head was on the 150?
1970 15' Allison/135 Chrysler stacker
RC Mod-VP Boats
IMPBA District 13
NAMBA District 3
12-27-2024, 01:27 PM #14Screaming And Flying!
- Feb 2015
- Ontario
- 8,108
- 205
- 323
- 1930
- 2011
Last year 150 is '75/76. By then the previous design head wether small or big bore was not used. But.. maybe some carried over by availability.
Like I said, stamped codes on both block and head will possibly id it.
It could be a 135 head cut tighter or a non stamp cut tighter to yield the 195psi with the ex height.
If it's the previous style the strike pad below #4 has the stamp, ex 372.
The 150 years '71/72-76 had two styles of head possible wether small or big bore.
It's easy enough to determine what the powerhead is with the head removed and a view of the top rings and ports and other details.
Measured stroke to rule out a later crank swap or different powerhead too.
If you were to id it with the cowl style and trim , that latch ended earlier in '73 , but did they continue it on the stackers?
A closer look it the setup is needed.
At some point a' 76 96ci 105 might have been dropped on it with the stacker trim and TC carbs, things happen over 50yrs.Last edited by FMP; 12-27-2024 at 01:52 PM.
Mark Poole ModVP liked this post
12-28-2024, 06:11 PM #15
Good info. Thanks!
RC Mod-VP Boats
IMPBA District 13
NAMBA District 3
Chrysler Racing Outboard
By gem56 in forum Outboard EnginesReplies: 2Last Post: 02-10-2023, 11:29 PM -
New Chrysler/Force Outboard Factory Racing Complete Lower Unit
By faztbullet in forum Ebay Listings and Other Internet ListingsReplies: 1Last Post: 12-01-2017, 06:55 AM -
Wanted Chrysler Racing stacker outboard stacks
By 1 off gn in forum Parts WantedReplies: 2Last Post: 02-05-2017, 08:04 PM -
History of the Chrysler Racing Outboards & evolution of the racing lower unit
By Mark75H in forum Outboard and Racing HistoryReplies: 28Last Post: 11-23-2015, 07:37 AM -
WANTED---Quincy Looper Outboard Racing Engines
By Jeff Lytle in forum Outboard and Racing HistoryReplies: 0Last Post: 05-31-2008, 11:12 AM
